Bad valve Hi, so she back fired. Drove the Coupe for about twenty minutes with no problems. Stopped for gas when I started her up the engines began knocking. Sounds like a valve. Any ideas as to what has happened. If it is say a Brocken spring on a valve can I replace it without yanking the engine? Thanks
Re: Bad valve Do a compression check.
If you had valve seats installed, that would be my first guess as to the problem. |
Re: Bad valve Possible carbon broke loose and on top of the piston?
Is engine misfiring? |
Re: Bad valve Hi Gino,
Absolutely no doubt about it ..... that any definite, engine internal knocking translates into immediate dismantling to investigate where the sound is originating. This is not like the song your engine is singing: "You keep a knocking but you can't come in." Get your wrenches. Hope this helps. |
Re: Bad valve If you want more than guesses you're going to have to do some troubleshooting and get the info back to those who can give you advice. Check compression, pull off valve cover and look it over, try to define noise and location as best you can. Short individual plugs and note any change in sound, etc.
Re: Bad valve The short answer to your question is, NO, you dont have to tear the whole motor down to change a valve spring. I hope that is indeed your only problem. Good Luck
Re: Bad valve answer to your question about pulling the engine. valve service can be done through the side inspection cover under the intake and ex ports. I made a spring compressor by welding two old wrenches together and grinding the 1/2 in open end to sharp wedge to get into the spring and use a intake stud and wrap wire from stud to wrench to act as pivot. you have to be careful I took a patch of skin off my thump tip. when the spring retainer slipped off the wrench when I was placing the keeper.
Re: Bad valve Again, "engine internal knocking translates into immediate dismantling to investigate "where" the sound is originating."
Very inexpensive investigation .... only $6.99 .... if you do not have one ..... get it tomorrow from Amazon if you have Prime. ----------------------------------------------------------------------------------------- ABN Mechanic's Stethoscope by ABN $ 6 99 Prime Get it by Tomorrow, Mar 23 4 out of 5 stars 48 ------------------------------------------------------------------------------------------------- Unless you like to read guesses for a few days, you can immediately bypass 50 Model A sincere Forum guesses from 50 past Model A owners' knocking experiences. First rule for solving, is always to "find" the problem. |
Re: Bad valve Quote:
Re: Bad valve Just KNOCK, my compression guage is there, on the coffee table!
Bill Loanatool |
Re: Bad valve If you have a HF near you. $3.99, plus a free gift. It looks identical to HL's.
http://www.harborfreight.com/mechani...ope-63296.html |
Whatever? Just hope it is something simple to fix. |
Re: Bad valve Ok, great info. Gonna wit for by brother to drive down from Maine. Together we will begin the trouble shooting. I always appreciate the help so I'll get back to the ford barn and let everyone know what comes out of it, thanks very much.
Re: Bad valve Gino,here is a good chart that might help.
John http://www.foxvalleymarc.com/Tech_se...ne_noises.html |
