The Ford Barn
-   -   CCPU?? latch comparison (https://www.fordbarn.com/forum/showthread.php?t=217129)
wrndln 03-21-2017 09:54 AM
4 Attachment(s)
I bought what I thought was a 28 to mid 30 CCPU door latch at a recent swap meet. When I compared it to a known CCPU latch I have, I noticed several differences. First the handle has a slight offset (first picture). Second, the main part is shaped differently (square) than the known CCPU latch which is somewhat rounded on the bottom. Third, there are no D nuts on the main plate to mount the latch, just holes. The gray latch mechanisms look the same as the known CCPU latch. Could the gray latch be for a model T? Any help identifying the gray latch would be appreciated.
I am attaching some picture I took of the questionable latch (gray finish) and what I am sure is a CCPU door latch next to it.
Rusty Nelson
d.j. moordigian 03-21-2017 10:29 AM
Re: CCPU?? latch comparison
Rusty,
I always considered those "T"......along with the non checker board doors.
I'm sure it could be modified to fit an A door tho...
wrndln 03-21-2017 11:05 AM
Dudley,
I looked at Lang's model T catalog and I could see no latches like this one. The 26/27 latches look like 28/mid 30 latches. I doubt earlier T's would look anything like the one in question.
Rusty Nelson
Hitman 03-21-2017 02:43 PM
The square latch (grey) is T, the other latch with the rounded lower corner and D nunts is 28-29 truck.
wrndln 03-21-2017 02:50 PM
I agree, the mystery latch is for a 26/27 model T closed car. Mystery solved. Thanks all for the help.
Rusty Nelson
Gunmetal blue2 03-21-2017 04:40 PM
Mine look like yours, the one is for the left side the other for the right side. I have took both apart to restore them. What I found was one was made for a lock devise and one wasn't. The one that doesn't lock with a key locks when you slide the handle forward or backwards (sorry be a few years cents I rebuilt them. lol all times setting in.
SeaSlugs 03-21-2017 08:26 PM
drivers side latch backwards locks it
Karl Wescott 03-22-2017 04:59 PM
My understanding is the 1926-27 Coupe-Tudor latch is basically the same as the 1928-29 closed pickup, with the exception of having provisions for a key lock on the right side. They will have "D" nuts or threaded holes for mounting. I have a pair of latches with the countersunk holes and the square corners that I took off a pair of 1924-25 coupe (wood framed) doors.
