cam replacement I have been pondering changing the camshaft in my A without removing the head or the pan. How frustrating do you think this is going to be?
Re: cam replacement Frustrating. How do you plan to hold the valves up with the springs on unless you can get the springs off without pulling the head off. And if you do get the cam out, what are you going to do with the old lifters? Run them on a different or new cam?
Re: cam replacement Original lifters have a hole in the side that was put there to hold the lifter up out of the way of the cam----but the valve adjustment would only be still good if the replaced cam has the same size base circle
Re: cam replacement Where there's a will there's a way
Re: cam replacement Mechanic friend loosened & slid back the convertor, took off the timing chain & changed the crankshaft on a 277 Plymouth V-8, with the engine IN THE CAR! Was it worth it, HEAVENS NO!!!
Bill Amazed |
Re: cam replacement Quote:
Re: cam replacement When I worked for a Ford dealer back in 56-57. I use to change the cams in there V8 engines with out taking the engine out. We got paid by a flat rate for each job. So if you could find a way to save time you made more money. But it was over head valves, which made it much easier. Now if you take the head off you might be able to do it. Just lift the valves and use old fashion spring clothespins to hold them and the lifters up.
Re: cam replacement harry,
I have done this once before. Been a while but here's what I did. of course removal of at least the carb and intake /exhaust if you wish for more room. valve cover off,. distributor, distributor shafts and oil pump drive removed I released the valve springs with removal of the keepers. Keep the valve springs in and you can wire up the valve lifters with some thin mechanics wire to the valve springs. In doing so you can turn the valve springs to advance the wire up bringing the lifter up. remove the cam, reinstall new with timing gear of your choice and make sure all is aligned. adjust all lifters to desired clearance. You can use the service bulletins rule of 9 I believe in the stock Model A bulletins. I removed a HP cam and went back to a stock touring cam. Larry Shepard |
Re: cam replacement 1 Attachment(s)
Larry Shepard |
Yup, the ole clothes pin method :) ! Know it well and just used it not long ago to do same job on a B block. One tip though...try to use new (stronger spring) pins and do not put the old ones (soiled with you know what) back into laundry bag....and think that no one will notice :D:eek: !! |
I'm only 100 mi away, so if you need any help....give me a call :) |
Re: cam replacement remove the cam, reinstall new with timing gear of your choice and make sure all is aligned. adjust all lifters to desired clearance. You can use the service bulletins rule of 9 I believe in the stock Model A bulletins.
I removed a HP cam and went back to a stock touring cam. Larry Shepard[/QUOTE] Larry -did you have any problem getting the keepers back on the valves |
Re: cam replacement A lot of money to spend. If it were mine I would replace the lifters springs valves and put on a high compression 5:1 head
Re: cam replacement I did this, too. Not a big deal. Hardest part was taking radiator and paraphernalia off.
I used the wire in spring method to make very sure a tappet doesn't drop down while cam's out. I think this can only work with adjustable tappets, only way to get clearances right. My humble opinion... |
