The Ford Barn
-   -   Piston ring end gap (https://www.fordbarn.com/forum/showthread.php?t=216732)
1crosscut 03-14-2017 09:23 PM
Piston ring end gap
What should the end gap be on rings for an engine bored .040 over?
SeaSlugs 03-14-2017 10:44 PM
Re: Piston ring end gap
CHECKING COMPRESSION RING GAPS
RECOMMENDED
AUTOMOTIVE COMPRESSION
RING GAP CLEARANCES
Cylinder .............................Ring Gap
bore Diameter............... Ring Gap Tolerance
1.0000" to 2.3624".......... .006 to .014
2.3625" to 2.9524".......... .008 to .016
2.9525" to 3.5424".......... .010 to .020
3.5425" to 4.3299".......... .012 to .022
4.3300" to 5.1174".......... .014 to .026
5.1175" to 5.9049".......... .016 to .030
5.9050" to 6.8899".......... .020 to .035
6.8900" to 8.9999".......... .024 to .041
I got that off a different forum and they got it from hastings the piston ring manufactuers site. No idea if its relevant but a piston is a piston and ring a ring...i think
BILL WILLIAMSON 03-14-2017 10:54 PM
An OLD "rule of thumb" was .003" for each inch of bore.
I DON'T KNOW IF HIS IS ACCURATE OR NOT??????????? I would follow your ring makers' instructions!
Bill W.
SeaSlugs 03-14-2017 11:10 PM
Bill W.
well going by the chart I found that's not a bad rule of thumb, its pretty close to that.
BILL WILLIAMSON 03-15-2017 09:40 AM
Some might think that LESS gap is BETTER, WRONG!!! If you ran OUT of clearance, just think about the ring WEAR & SCORING:eek:
As in MOST things, JUST USE COMMON SENSE!
Bill W.
wrndln 03-15-2017 09:46 AM
Is the best way, maybe the only way, is to put the top 2 rings in the cylinder bore and use a feeler gauge to check the gap. I would think ring manufacturers would make the rings with the correct end gap right out of the box. I assume the oil rings don't need to be checked - right?
Rusty Nelson
d.j. moordigian 03-15-2017 10:51 AM
RECOMMENDED
RING GAP CLEARANCES
Well ...close , but not true, it depends.
Bill W.
Good rule Bill..003"-.004"
Rusty Nelson
I use a "squaring ring" that I've made for the common engines that I do. If it's an odd, not so popular one, I use a small square
to check it in the bores. I always check one piece oil rings and if 3 piece,
I check the rails. The piston material dictates the end gap,...cast and forged
run the same end gap,...Hyperutectic runs more end gap. The engine application, blown, fuel, NOS all change the end gap.
BILL WILLIAMSON 03-15-2017 12:39 PM
There you are, d.j, Dog here,
Thought you were sleepin' under the Roadster.
Dad still has that CREEPER for you, with 6 wheels & a tilt up pillow!
Buster T.
1crosscut 03-15-2017 09:11 PM
Thanks gentlemen.
