The Ford Barn
-   -   35 Running Board Repair (https://www.fordbarn.com/forum/showthread.php?t=216349)
32Bee 03-08-2017 07:50 PM
I'm working on an original pair of 35 running boards and need some advice on
what product to use to fill pits and imperfections on the cover side. I read in
another post quite some time ago that it's best to use something other than
plastic filler. What product is available that would be suitable to use that would
have metal flakes in it which someone suggested in that post?
Peter
paul2748 03-08-2017 08:38 PM
Re: 35 Running Board Repair
I have used a product called Alvin Lab Metal with very good results. It is a paste like product that hardens like metal. Can be filed, drilled, etc when fully cured.
This stuff has been around for ages, so it must work.
Lawson Cox 03-09-2017 01:28 AM
PC7 is good too. Doesn't crack or peel off. Easy to work with. Sands easily.
32Bee 03-09-2017 06:46 AM
Thanks guys. I have some fairly new PC-7 left over from my steering wheel
repair. I'll use that.
Peter
