The Ford Barn
-   -   Sun EB5 Transmitter (https://www.fordbarn.com/forum/showthread.php?t=213334)
AL in NY 01-23-2017 03:18 PM
Sun EB5 Transmitter
I acquired an early Sun EB5 transmitter for my Model A RC2 tachometer. I have wired up a small power supply circuit to replace the internal battery(batteries?). I am replacing all the capacitors inside the transmitter with new ones, but I found only one soldered in battery inside. This transmitter is for a 6 volt/4 cylinder application. Most of the diagrams I have found show two 1.35V mercury batteries. This one looks like it just had one but I have one way to know for sure. Does anyone know if this transmitter uses one or two 1.35V batteries??????
flatheadmurre 01-23-2017 03:35 PM
Re: Sun EB5 Transmitter
Think they used 1 or 2 batteries in combination with different values of capacitors to suit different numbers of cylinders.
Bob C 01-23-2017 04:08 PM
Found this on the HAMB.
skryla said:
I have an EB-5a 6 volts, 4 cylinder. It doesn't seem to have ever had a second battery. Anyone seen one of these? Does this still take a 1.35v or 2.70v?
Yes the 4 and some 6 cylinder transmitters used a single 1.35v battery instead of two.
Automotive Stud, Jul 14, 2014
flatheadmurre 01-23-2017 04:17 PM
And the early ones used a single flashlight battery under a small lid.
AL in NY 01-24-2017 01:05 PM
Thanks Guys, now I can proceed with the rebuild of the transmitter.
