The Ford Barn
-   -   Any recognized this tool (https://www.fordbarn.com/forum/showthread.php?t=213158)
glennsanders 01-21-2017 02:01 PM
2 Attachment(s)
Thanks
sunshine 01-21-2017 02:46 PM
Re: Any recognized this tool
Is it not a tool to set the teeth on a hand saw .
Capt Kirk 01-21-2017 03:34 PM
I see...eliminate all other possibilities and you're left with the solution! I'll play.
It's not a nut cracker :D
V8COOPMAN 01-21-2017 03:48 PM
It's not an ear piercer. DD
J Franklin 01-21-2017 03:54 PM
Snap or grommet setter?
Bob C 01-21-2017 04:46 PM
I think saw set, look at the link. http://www.ebay.com/sch/i.html?_saca...&_skc=50&rt=nc
Bob
cmbrucew 01-21-2017 04:49 PM
I will take nutcracker for 10.00
Bruce
ford38v8 01-21-2017 04:56 PM
It is an excellent device, designed to display the beautiful granite kitchen countertop you installed for your wife.
Otherwise, it may be an upholstery staple puller. Just a guess.
jimTN 01-21-2017 05:16 PM
It is a saw set!
flatford8 01-21-2017 05:17 PM
Thats one of the best looking thingamajigs I've seen. Great patina!!.... Mark
glennsanders 01-21-2017 05:26 PM
Bob I think u got ,I had not a clue what it was.To set pitch on saw blades , didn't know that there was tool for that? There is like a hundred for sale on eBay.Its now a wall hanger.Thanks for inputs
V8COOPMAN 01-21-2017 05:26 PM
WOW! This is the perfect example about how important one lousy QUESTION MARK can be, because without the correct punctuation, I (like a couple of others) saw:
IT IS NOT a tool to set the teeth on a hand saw .
DD
Ggmac 01-21-2017 07:07 PM
Ha , I was just using that same tool to set the teeth on and old blade . Many adjustments .
It's a valuable tool still working .
Can anyone please post a pic of mine ? I only know how to email !
glennsanders 01-21-2017 10:26 PM
Post a pic in use also please .
Russdadto5 01-22-2017 09:31 AM
Looks like a crimping tool for wire ends .
FlatheadTed 01-22-2017 02:39 PM
I am with wire ends ,its got a point to push the centre in over the wire ,
glennsanders 01-22-2017 02:46 PM
Show me how it works
Ggmac 01-22-2017 03:13 PM
I will but it'll be tomorrow now . It looks like mine has another adjuster on it . I'll get the blade out and set a few teeth . Speaking of teeth , I chipped my front tooth today trying to open an old can of gasket shellac . Dumb . Pliers were in my pocket .
Ggmac 01-22-2017 03:16 PM
I can also set the teeth on 2 man crosscut saws . I use mine on bandsaw blades and hand saws , bow saws etc . The pics I sent still have the wood dust on it , if you see the white/yellow specs .
FlatheadTed 01-22-2017 04:35 PM
No I have changed my mind as said ,saw Doctors gullating tool
