EAB to 39 toploader I have a 52-53 EAB engine I am working with and I am looking to mate it to a 39 Ford transmission for a car I am trying to build. I have no bell housing yet. I am guessing that the 39 trans will not bolt right up to the EAB bell housing and I will need some sort of adaptor. A stock 52-53-clutch and flywheel will be used. Where can I find an adaptor for joining the 39 trans to the 52-53 EAB type bell housing. thank you for the help.
Re: EAB to 39 toploader 1949 thru early 51 Mercury cars and 8BA family pickups used the stamped steel (or cast iron on 4-speed truck applications) half bell that will fit the 8BA family of engines and any of the early round pattern transmissions with 1 3/8" 10-spline input shaft.
Re: EAB to 39 toploader Use a merc 49/51 housing and oil pan or a 49/51 PU. Make sure you get the right starter plate. All stock stuff here.
Re: EAB to 39 toploader The 48-52 truck bell housing (cast iron) or the 49-50 Merc bell housing (stamped steel) will bolt right up to your motor. Be sure to use the matching starter plate for whichever bell housing you use. Either type will accept the 32-39 type top loader 3 speed transmission.
Your other problem is the flywheel. If it's drilled for a 9.5" diameter pressure plate, you can't use it......unless you have it redrilled for a 9" or 10" or the truck 11" clutch bolt pattern. Or you can locate a 48-52 truck flywheel which is drilled for the 10" or 11" clutch. The 9.5" clutch is meant to be used with the transmissions with the smaller input shaft and you would have problems with the throw out bearing. |
Re: EAB to 39 toploader Quote:
Re: EAB to 39 toploader Thanks for the info. Much appreciated.
Re: EAB to 39 toploader Listen to Mac vp he knows what he is talking about. There can be problems with throw out bearing and carrier using 0.5 pressure plate.
Re: EAB to 39 toploader I suppose it's possible for someone to combine the 9.5" pressure plate with a '39 type transmission, but I believe the three fingers on this pressure plate are going to be too close to the front bearing retainer of the transmission when the clutch is depressed. Since the pressure plate (and the release fingers) are spinning with the engine flywheel, they typically hit the front of the snout of the transmission front bearing retainer. At the same time they will chew into the carrier hub of the throw out bearing. Usually you hear the scraping sounds and you'll find lots of metal particles inside the bell housing. We've seen this before in transmissions that have come into the shop....
Re: EAB to 39 toploader Mac's right. The throw out for the 9.5 Long type is for a 1" 10-spline trans input. That small input uses a small diameter throw out set up for the Ford car type full bell housing. It would be interesting to find out how 51504bat dealt with that. Most folks change over to the 9 or 10 inch Long type by re-drilling the flywheel or they can use the 49/E51 Merc Borg & Beck 10-inch set up & flywheel since they all use the early type throw out for 1 3/8" 10-spline input.
Re: EAB to 39 toploader Thanks guys for the great info. Now I have a good idea of the pieces I am going to need to bring together. I need to make sure that this block has no cracks and is doable before I start spending the money for the parts. Had a good offer here on Ford barn for a bell housing. Keeping it in mind.
Re: EAB to 39 toploader Can an open shaft output be put on the back of the 39, allowing for a u-joint/drive shaft/differential?
Or if I use the 39, will I be locked into a closed drive system? |
Re: EAB to 39 toploader Anton: Be sure to read ALL of the thread below including all the links included in the thread. It will tell you what you want to know. 8BA and EAB have the same block. 1949-53 Ford and Mercury V-8's are the same block. The Merc 4 in. crank gives it 255 cu.in instead of 239 cu. inch.
https://www.fordbarn.com/forum/showth...d+transmission |
Re: EAB to 39 toploader Thanks. Need the info.
Decisions based on good info now will prevent lots of future trouble in the garage. |
https://www.fordbarn.com/forum/attach...6&d=1459964038 |
Re: EAB to 39 toploader 3 Attachment(s)
