The Ford Barn
-   -   1950 upper radiator hose (https://www.fordbarn.com/forum/showthread.php?t=211427)
35 coupe 12-24-2016 05:03 PM
Who sells good quality upper radiator hoses so I can get away from those tubes. Found out the ones I bought are 3 years old and the paint or powder coating on the inside was all corroded and restricting the flow. 1 1/4 inch ID. Thanks
12cliff23 12-24-2016 05:23 PM
Re: 1950 upper radiator hose
I saw some in C&G with ford scripts I think
cliff
JT FORD 12-24-2016 06:24 PM
I have Dennis Carpenter's with Ford scribe on them.
V8COOPMAN 12-24-2016 06:30 PM
Surely you guys don't believe that FORD made those hoses, much less on this continent? DD
42merc 12-24-2016 07:07 PM
Are you talking truck or car ?
Trucks use the metal tubes & I don't believe anyone makes a total hose replacement.
35 coupe 12-24-2016 08:36 PM
1950 f1 truck,
Tony, NY 12-25-2016 07:50 AM
Truck upper radiator pipe is different.
http://www.macsautoparts.com/ford_tr...er-239-v8.html
estout81 12-25-2016 05:20 PM
Check with NAPA as they had them for my '51 car. Made in USA and looked fresh.
Barry-ct 12-25-2016 08:24 PM
48-52 Trucks used the metal tubes. I had a bunch of hoses a few years ago that were all rubber and fit the trucks. They were made for Mopar of all things. There are new metal tubes sold thru the repro dealers. Coat the insides with an epoxy paint so they will last.
