The Ford Barn
-   Model T (1909-1927) (https://www.fordbarn.com/forum/forumdisplay.php?f=2)
-   -   Model T VIN? (https://www.fordbarn.com/forum/showthread.php?t=210869)
Nickpohlaandp 12-14-2016 09:41 AM
Model T VIN?
Does anyone know where the VIN would be located on a 1927 Model T Sedan? I appreciate any input you might have. Thank you.
Jack Innes 12-14-2016 10:00 AM
Re: Model T VIN?
The engine no. is the VIN. It will be on the left side of the block above the water inlet fitting. On a 27 the same no. should be stamped on the frame about where the passenger's right foot would rest. It is not unusual for these not to match due to an engine replacement at some time.
Nickpohlaandp 12-14-2016 10:07 AM
Re: Model T VIN?
Thank you. Would the number on the frame be visible without removing the body?
redmodelt 12-14-2016 10:44 AM
Re: Model T VIN?
Yes just take out the floor board(s). You might have to clean off the top rail of the frame to see it.
Nickpohlaandp 12-14-2016 11:45 AM
Re: Model T VIN?
Again, thank you very much.
Jack Innes 12-14-2016 12:35 PM
Re: Model T VIN?
http://www.mtfca.com/discus/messages/257047/308310.jpg
