The Ford Barn
-   -   steering worm gear (https://www.fordbarn.com/forum/showthread.php?t=209789)
bnchief 11-26-2016 06:51 AM
steering worm gear
Looking at the worm gear on my 30 tudor to replace i assume it will go on either way or is it directional?
SwansEarlyFord 11-26-2016 12:42 PM
Re: steering worm gear
Yes it is.
bnchief 11-26-2016 04:47 PM
After i got the old one off my question is answered that new one is a real pita to pu back on
Terry, NJ 11-26-2016 08:12 PM
You guessed it! The new one has to be fitted. I wound up filing it down a little and tapping the the shaft a putting a piece of ready rod in the threaded rod and screwing a nut and large washer to pull it down into place. This was four days after I started the job with a large lead hammer and a propane torch. BIG PITA!
Terry
Mitch//pa 11-26-2016 08:17 PM
In case you have not seen this
http://fordbarn.com/forum/showthread...highlight=Worm
tbirdtbird 11-26-2016 11:42 PM
midgetracer 11-26-2016 11:50 PM
I've used that method 3 times and had great sucess. Quick and easy. I once bent a shaft trying to drive one on with a brass sledge.
bnchief 11-27-2016 05:54 AM
Mitch your method is what i am using but this new gear is really galling the shaft bad i know it should be tight but not this tight and yes i did line up the key part of the gear on the shaft and got it started real good also it is the last inch that does not want to go.
