Rear tube shock kit 41 Ford 1 Attachment(s)
While searching the Internet I found information on this kit to convert 41-48 Fords to tube shocks, is this a Ford kit or aftermarket?, do they still make them.
Re: Rear tube shock kit 41 Ford Ford starting using tube shocks in 48 on some models, maybe even late 47 .The green bock I have shows the parts they used.if you want a copy I will try to post it .
Re: Rear tube shock kit 41 Ford Quote:
You can buy similar lower brackets from Pure Hot Rods and most vendors sell a stud to mount on the top member. You will probably have to measure your installed height to get the shocks. |
Re: Rear tube shock kit 41 Ford If the rear cross member is boxed like the 46-48 you will need a upper mount that goes all the way through. I had a set machined locally, worked real well.
Re: Rear tube shock kit 41 Ford There is a company that makes an exact kit like the one you show , all you need is the monroe shocks ,i have this on my 40 its great. The company is called pure hot rods ,i think the kit minus shocks was $115.00
