The Ford Barn
-   -   Banjo Wheel for '35 (https://www.fordbarn.com/forum/showthread.php?t=209580)
Scott754 11-22-2016 09:28 AM
Banjo Wheel for '35
1 Attachment(s)
I have a '35 Fordor that had a Banjo wheel installed when I purchased it (picture attached). From the prior posts describing various banjo wheels, this seems to be a '36 wheel. The paint is chipping, and appears to be brown under the black paint. I was going to repaint the wheel, but also the spokes are loose, so the wheel 'rocks'. I don't know if there's an easy fix for the loose spokes, so I was considering buying a new wheel. Will any of the new/reproduction wheels that are for '36-39 work as a replacement for this current wheel, accommodating the light switch I have on the wheel? Would there be difficult modification needed to make a new wheel fit? Thanks
TJ 11-22-2016 10:01 AM
Re: Banjo Wheel for '35
The repo 39 banjo will fit your column. There may be a problem with the horn rod, but I'm not sure. The diameter of the horn button assembly may be different than the diameter of the new wheel. I'm sure someone here can answer that question.
JM 35 Sedan 11-22-2016 10:24 AM
2 Attachment(s)
If you are not interested in having a banjo style steering wheel, you might want to consider a standard three spoke repro '36 steering wheel. It would look and work just like an original '35 wheel except there would be no little ribs molded in around the grip ring. Everything would bolt back in place as an original '35 steering wheel.
Scott754 11-22-2016 01:05 PM
Thanks John, even though I know it's not standard on the '35s, I do like the banjo wheels and am looking to repair/repaint or replace with another banjo.
JM 35 Sedan 11-22-2016 09:14 PM
Oh, okay, I guess I misunderstood your actual question....
"I don't know if there's an easy fix for the loose spokes, so I was considering buying a new wheel.Will any of the new/reproduction wheels that are for '36-39 work as a replacement for this current wheel, accommodating the light switch I have on the wheel? Would there be difficult modification needed to make a new wheel fit?"
....and did not understand that a new reproduction wheel had to be another banjo.
Mike in AZ 11-22-2016 09:49 PM
search for repairing the steering wheel....maybe with a little work, you can freshen and tighten up your wheel so it looks and feels good.....i know it's been talked about before using materials from Home Depot?....good luck....Mike
TJ 11-23-2016 11:33 AM
If your spokes are loose at the hub the problem is finding someone to weld the spokes to the diecast hub. The spokes are stainless, so I'm not sure that stainless can be welded to the diecast. Also check your keyway in the wheel. Lately I've seen two original wheels with split keyways.
