Optima battery that will not hold a charge I have a 1 yr old Optima battery that will not hold a charge. We were gone on vacation for 10 days and I came home to a completely dead battery. Would not register even one volt. I placed it on a slow charger for 24 hours and was able to start the car and driving around I parked it for three or four hours and came back out to start it and it was down to 4 V. I recharged it again this morning and had a voltage of 6.42 volts. I have let it sit now for approximately 2 1/2 hours. And it is down to 6.24 V. I am going to place it back on the charger again and disconnect the battery cables from the car and see if I get a voltage drop after setting for a few hours. Any suggestion ?
Re: Optima battery that will not hold a charge I would check the cutout on the top of the generator. If the points are stuck closed, it will drain a battery quite dead.
Re: Optima battery that will not hold a charge take it to the dealer and have them check the. Condition of the battery! Wayne
Re: Optima battery that will not hold a charge Something is more than likely drawing the battery down. Just a note the optimas dont like a slow charge ,if ya googe the optima charging , they like a max charge with a lead acid battery hooked in parallel with jumpers. I have taken a few that was dead and charged this way revived them all..
https://www.optimabatteries.com/en-u...harged-battery |
Re: Optima battery that will not hold a charge Quote:
I did not see the other post with the same question. I answered the first one I saw, which is the later one. Now that I read the other post, I don's see anyone suggesting the cutout. as the possible problem. So I think that is still a fair suggestion. I don't know why people post the same question twice. Computer glitch, I suppose. I don't think anyone does it on purpose to be annoying. |
Re: Optima battery that will not hold a charge I would agree that the first thing is a draw, so, the first question is always, has a check for a draw been done ?
To check, just disconnect a battery cable and install your test light between the unhooked cable and battery post and see if the light comes on. If it does there is a draw. Then just keep disconnecting things until the light goes out, thats the draw. Usually on an 'A', its the brake switch or interior light. |
Re: Optima battery that will not hold a charge [/B]
Re: Optima battery that will not hold a charge Nobody posts twice on purpose:
I have made two posts-threads myself ... if you make a post and go back the original thread to see what you posted and do not refresh the original thread, it looks like the first post never happened. So I posted again and two threads were on the system. That is how it happened with me ... When this happens to me I just click the "report" button and ask Ryan to delete the duplicate post (or in this case duplicate thread). Bubba's post says that he had same problem I wrote about and he fixed it with Optima procedure like I did, but the first thread does not reflect this ... That is what I meant about confusion... I do not want to start any trouble over this ... |
Re: Optima battery that will not hold a charge Thanks for explaining how two threads happen.
That pesky refresh button. |
Re: Optima battery that will not hold a charge While nearly dead Optimas do not accept recharging by traditional chargers, and require another 6 volt battery in parallel hooked up to the system, I have seen some 12 volt chargers at Harbor Freight that are designed for Gel Batteries, which I guess Optimas are classified as.
