1953 Truck 6 Cylinder Hi guys I am hoping someone can help me with a problem I am having tearing down a 1953, 215 cid, 6 cylinder. I am trying to seperate the head from the block but, there is a oil tube that runs from a cam bearing in the block to the rockers in the head. Does anyone know how to remove the oil tube with out ruining it. I hate to ruin something only to have to cobble it later.
Thanks, Tony |
Re: 1953 Truck 6 Cylinder That tube has a captive rubber square ring on the bottom. Twisting it back and forth while pulling upward usually does the trick.
Re: 1953 Truck 6 Cylinder Thank you MMB for your reply, is there a trick to getting it back in later?
Re: 1953 Truck 6 Cylinder All things were made clear now that I got it out. Thanks again
