The Ford Barn
-   -   What does this bellhousing fit? (https://www.fordbarn.com/forum/showthread.php?t=208303)
Fredb_ 11-01-2016 05:00 PM
4 Attachment(s)
This bellhousing will take the Ford V8 3-Speed transmission, but appears to be deeper than the typical 49-53 8BA style. Is it for the H Series Truck?
toby 11-03-2016 11:07 AM
Re: What does this bellhousing fit?
4 Attachment(s)
The bell housing is from a 48/49 to 51 Truck. It will fit a 226H or 254H Flathead 6. This bell/rear engine plate(or starter plate) will not interchange with the car components.
41Joe 11-03-2016 12:06 PM
Are you talking about the V8 car components or are there differences between the car and truck H series components?
V8COOPMAN 11-03-2016 12:48 PM
you've gotta remember that the '49-'51 CARS did NOT use the old 3-speed with the old, round bolt pattern. DD
Bruce Lancaster 11-03-2016 01:24 PM
I think Ford cars did pick up the H6 for 1948, though. I'm not familiar with the details for non-V8's, though.
Tim Ayers 11-03-2016 01:26 PM
That does not look like the truck V* bell housing I have. It isn't that deep. Like someone said, it may be for a 6 banger.
V8COOPMAN 11-03-2016 01:46 PM
It IS for a 6-cyl. That's what "G" and "H" signifies. That goofy "un-round" hole in the middle of the plate denotes 6-cylinder. DD
https://www.fordbarn.com/forum/attach...7&d=1478189073
1946 ford convertible 09-28-2024 09:47 PM
Hi, just ran across this. "The bell housing is from a 48/49 to 51 Truck. It will fit a 226H or 254H Flathead 6. This bell/rear engine plate(or starter plate) will not interchange with the car components." <-- Does this mean I can't bolt it to a 1947 sedan 3 speed side shifter with a closed driveshaft? Is there a difference between a 1947 V8 3 speed and a 6 cylinder 3 speed? Thanks so much. I hope this note finds you well. Matt
cas3 09-28-2024 11:03 PM
No, you need one for the v8. Go to Van Pelts web site to see all the variations of starter plates
