The Ford Barn
-   -   torque tube seal and bearing race (https://www.fordbarn.com/forum/showthread.php?t=208143)
chkolar 10-30-2016 03:58 PM
What direction does the bearing race and the seal go for removal? Out the front or back? I have everything out including the drive shaft.
Tom Endy 10-30-2016 04:21 PM
Re: torque tube seal and bearing race
They both go out the front. Place the drive shaft vertical on a block of wood on the floor with the spline end up. Place a 1&1\16" six-point socket over the spline. Put the torque tube over it and bounce it several times. This will force the seal and the bearing race out. Best to hold a rag over the end to catch them as they come out.
Tom Endy
john charlton 10-31-2016 05:41 AM
When you reinstall the race you will see a dimple on the outside,this must align with a recess in the tube neck to locate the race . I know you know this but just in case .
John in lovely sunny morning Suffolk County England
Jacksonlll 10-31-2016 06:45 AM
I assume you already have the snap ring out. Not easy the first time. Very easy the sixth time. We had problems.
Jim Brierley 10-31-2016 10:28 AM
Face the seal so it keeps the oil in the trans, not the rear end.
Indiana A. Lover 10-31-2016 06:50 PM
John We have just about Combined all our field Corn , It looks bald around here now. The wife says Hello and Happy Model A. Just wanted to say Hi
