The Ford Barn
-   -   1928 vs 1929 and 1930 vs 1931 models... (https://www.fordbarn.com/forum/showthread.php?t=206508)
Steve Plucker 10-08-2016 10:32 AM
At what point in production of the 1928 and 1929 models and the 1930 and 1931 models did FORD distinguish between the years (28 vs 29 and 30 vs 31)? In other words what was the specific "change" that FORD used to distinguish the difference?
For 28-29 was it the change in the clutch system (Nov. 1928) or was it the change to the Twolight system (February 1929)? or another factor?
Same for the 30-31 models?
Thanks.
Pluck
Jim Mason 10-08-2016 10:49 AM
Re: 1928 vs 1929 and 1930 vs 1931 models...
I've been, and still am, of the opinion that the concept of model change is a new invention. in 28 to 31 it was an evolutionary change. improvements were designed, and implemented. Some occurred at the year breaks, most were just put into production when ready. The change from the t like coupe pillar to the more streamlined bodies of the 30 is an example of the necessary year break change requiring major change in production lines. The very early, early, mid and late designations and 28-29, 30-31 the the evolutionary type. The ve e m late, are arbitrary and applied be restorers as a shorthand description. ford`s year change was more marketing than model change. ymmv
Russ/40 10-08-2016 10:49 AM
Tough one Steve. But, with your dauntless research, I betting you can figure it out.
BILL WILLIAMSON 10-08-2016 11:44 AM
For a long time, I had a '29 & a '30 5 Window Coupe, side by side. I could write a "book" about the all the differences!!! One looked like a FULL SIZED & the other looked like a MID-SIZED car. Even their "FACES" were different, but they both "TALKED" the SAME LINGO---------
Bill W.
Mike V. Florida 10-08-2016 11:05 PM
Thanks.
Pluck
The ads for the '30-'31 always show the different radiator shroud.
