Mercury Speedometer 1 Attachment(s)
I got the instrument panel opened up on the 52 Merc (carefully) today and can see what might be the problem. Seems like the return coil spring on the needle is all wound up, possibly twisted off or disconnected. I can't get any movement at all on the speedometer so I don't know if it has seized up or what. Its a King Seeley as are all the instruments. I'm thinking I will just clean it up, put it all back together and be content to live without a working speedometer.
Re: Mercury Speedometer Definitely repairable, now that you know what the cause is.
Re: Mercury Speedometer Quote:
Re: Mercury Speedometer Just box it up in a large enough box (maybe use an inner and a outer box) and insure it for enough to replace it if damaged. I have purchased several speedos over the years and they all arrived in one piece. Your speedometer is a very big part of your dash and I bet you will be happier once its working properly. I know I hate staring at gauges that dont work. PS:What part of Sask are you located in?
Re: Mercury Speedometer Find one on Flea-Pay as long as they guarantee it functions. That one is likely repairable but it might be more costly than finding another usable one that can be cleaned & lubed to make it go another 50+ years. The 1953 models used the same part number FAB-17255-E so you can google that & see what comes up. The chassis parts book I have stops at 1953 so it may also work on the 54 but I can't confirm that. Stay away from the rusty stuff and ask plenty of questions.
Have to say I'm impressed at the weight of that dash cluster housing. Must be more metal in there than an entire dash of a modern auto. |
Re: Mercury Speedometer If it is zinc die cast then that's why it's so heavy. Your lucky though. I had to take the whole dash out to work on my speedo in the 51. There is just not enough room to work on in under the dash and the panel waterfall won't clear the steering column even if you drop it down. I bought a clean looking instrument panel off the bay about 8-years ago and I only paid about 75 bucks for it complete. The panel was a little too pitted to use without getting it rechromed but the instruments were in great condition. The speedo out of that one fixed one of my 51s. I also used one of the gauges and some of the accessory retention hardware that is hard to source.
