Flushing Evapo Rust I did the LestOil shuffle on my rad in preparation for EvapoRust.
When the ER has completed its job, will the particulates drain thru the pet cock or should I remove the lower hose and pipe afterwards? Thanks Leo |
Re: Flushing Evapo Rust The petcock drain is small, it may get clogged! Why not remove the petcock, that would be a 3/8 hole!
Re: Flushing Evapo Rust I would remove the lower hose, then flush water through it as well as the block... Run the hose into the top water outlet neck of the engine and let it come out the lower pipe while it's still disconnected
Re: Flushing Evapo Rust Remove the lower hose and give it a very thorough flushing. Wait an hour and flush if again! Wayne
Re: Flushing Evapo Rust In my opinion, chemical treatments and/or flush/neutralizing should be done separately as in not connected together to avoid junk from the dirtiest component being transferred to the cleaner one.
Re: Flushing Evapo Rust Quote:
Re: Flushing Evapo Rust The beauty of evaporust is it does not have to be neutralized
I can't figger out WHO left me a patina'd, oversized, foot locker, to haul on Vermins' ZIP-A-RAK:confused:??? The Dog:cool: doesn't know, either:confused: Dad Mystified??? |
Re: Flushing Evapo Rust How does this relate to the question asked?👎
Re: Flushing Evapo Rust See Mitch's answer. Also, known as a back flush ...
