The Ford Barn
-   -   Forum and Restorer Save the Day (And Spark) (https://www.fordbarn.com/forum/showthread.php?t=206128)
jg61hawk 10-02-2016 08:43 PM
Long story short: I was just at the Monmouth County (NJ) Concourse De Elegance and an older gentleman(82) with a 1929 "A" Roadster stalled coming into the show. We got the vehicle pushed into its appropriate spot on the field. It will crank...but...the car had no spark.
Of course everyone gathers around and immediately thinks ignition...condenser, points, coil...you know. But based on this forum and The Restorer I know I want to check for horn and lights too and guess what...the car has NO LIGHTS, NO HORN. HMMM!
Based on reading here and in The Restorer so many times of the exact same thing I am somewhat sure of the path of the electric...battery to starter (so it cranks) but then onto ignition and AMP meter and coil that I know cranking has nothing to do with spark. I have read so often of bad AMP meters stopping the spark and we HAD BUT ONE TOOL, a screwdriver. We jump the AMP meter wires and BINGO the horn blows, the lights light and YES the engine starts.
Thanks to all who post here with problems and those who solve them because you will never know who reads what and how you help. We made quick work of a problem that seemed complex except for the fact that the forum and The Restorer had already planted the seed for solving it.
Mike V. Florida 10-02-2016 10:52 PM
Re: Forum and Restorer Save the Day (And Spark)
I love it when I hear things like this!
Chuck Sea/Tac 10-02-2016 11:00 PM
Good job! I'll bet it was pretty satisfying as well.
Tom Wesenberg 10-03-2016 12:27 AM
That was too easy..............just keep messing with it and changing parts. :D
Marshall57 10-03-2016 01:28 AM
Great story! you did better than I would have done. LOL
BILL WILLIAMSON 10-03-2016 07:21 AM
TIP: If something electrical fails & you "suspect" the ammeter circuit, just run a jumper between the junction box nuts.
Bill W.
Jim/GA 10-03-2016 12:37 PM
Bill W.
YES!!! ^^^^
What Bill says. :cool: You can be back on the road in very little time if this is the problem. If you SUSPECT a bad ammeter, you can try jumping across these two junction box nuts with any metal object as a quick test. It does no harm if you are wrong.
old31 10-03-2016 03:07 PM
Bill W.
Curious. If the ammeter is bad, then what is the jumper on the left and right post actually doing?:confused:
Signed
Electrically Challenged.
Jim/GA 10-03-2016 04:00 PM
Signed
It bypasses the bad ammeter. It allows current to flow from the battery to the coil (and lights and horn), where the burned out ammeter was not doing so.
You don't really NEED an ammeter to start, drive, etc. It just helps you keep tabs on current coming out of the battery and current going back into the battery (confirm generator is working). Most people don't look at it anyway!
Mike V. Florida 10-03-2016 11:12 PM
Shame really. It's a good tool to assist in troubleshooting if wired as the later cars. Turn on the key and you should see the needle move to the discharge showing current flowing to the coil and points to ground. Turning over the engine, the meter should "wiggle" showing the points opening and closing.
Mitch//pa 10-04-2016 06:43 AM
That depends if the points were closed after shutting down... If the points are open then you'll have no needle movement when turning the key on..:)
old31 10-04-2016 09:49 AM
Thanks for the explanation..
BILL WILLIAMSON 10-04-2016 10:05 AM
If you STUDY the wiring diagram, you'll find that the electrical system is QUITE SIMPLE!
Bill Simple
old31 10-05-2016 04:45 PM
Bill Simple
Nope, whenever I study wiring diagrams I find out that I am the one that is quite simple:eek:
