The Ford Barn
-   -   When did the 1931 one piece running board SPLASH APRON start? (https://www.fordbarn.com/forum/showthread.php?t=205263)
ItsA31 09-22-2016 12:47 PM
2 Attachment(s)
When did the 1931 one piece running board Splash Apron start?
Mitch//pa 09-22-2016 12:59 PM
Re: When did the 1931 one piece running board SPLASH APRON start?
I don't have the judging standards in front of me right now but my Tudor is August with the round speedo and one piece apron,,
Body is stamped from the Vancouver plant but has no Robertson screws....
Kurt in NJ 09-22-2016 01:10 PM
My coupe is April and has 1 piece apron
2manycars 09-22-2016 01:19 PM
Judging standards say September 1930
ItsA31 09-22-2016 01:22 PM
Thanks for helping me zero in on the build date of my truck. (The date is not shown on the seat riser cross member)
The one piece splash apron cut-in date is a lot earlier than I originally thought. Even earlier maybe?
I have the round speedo too. What was the cut in date for that?
My engine is dated April 1930. I originally thought is was a replacement engine. Could it be the original engine to my truck? I dont know the lag time between the engine build and the truck build. I do know it was built in Buffalo.
ItsA31 09-22-2016 01:23 PM
Wow, good to know.
Mitch//pa 09-22-2016 01:25 PM
You would have to get the frame stamping to see if it matches the engine... But that's under the apron / fender on the rail.... Does your title match the engine number??? If so it prob is original
Bob C 09-22-2016 01:26 PM
If I'm reading Steve Plucker's gas tank article correctly your tank was used
from June 1930 to about April 1931.
http://www.plucks329s.org/pdf/gastan...31gas_tank.pdf
Bob
ItsA31 09-22-2016 01:41 PM
Frame is unreadable since I'm not going to lift the body. Title was regenerated by the last owner based on the engine number...so no help there.
George Miller 09-22-2016 01:41 PM
I also had a couple of 1930 A,s with the one piece splash apron. both were original cars that were never restored. Both had round speedos. One was built November, one was October.
Mitch//pa 09-22-2016 01:46 PM
You do have the round speedo correct???
BILL WILLIAMSON 09-22-2016 02:31 PM
One piece splash aprons came about in mid '30, along with the ROUND speedo.
Bill W.
ItsA31 09-22-2016 03:56 PM
Yes, that's right, round speedo.
CHuDWah 09-22-2016 08:21 PM
Interesting. I used to have an August 1930 Closed Cab with round speedo and 2-piece aprons. Course Ford tended to use up old stock on trucks before going to new stuff.
Pmsqrd 09-22-2016 09:24 PM
I believe all 30-31 pick ups came with the round speedometer. The 30-31 style trucks were introduced mid 30 when the round speedometers were also introduced.
CHuDWah 09-22-2016 10:56 PM
Originally Posted by forever4 (Post 1358915)
All 30-31 body style pickups have two-piece fender & running board splash aprons. Right? :cool:
Dunno. Apparently the OP's 31 has one piece but they could have been changed in the last 85 years. ;)
1930artdeco 09-22-2016 10:59 PM
My 30 Town Sedan has two piece aprons and a round speedo.
Mike
CHuDWah 09-22-2016 11:12 PM
Well, sorta. The early 30 trucks had the oval speedo. These had a square cab similar to the 28 - 29 but there were some subtle differences. I guess it depends on one's definition whether these were truly distinct 30 models.
100IH 09-23-2016 10:19 AM
I would think that the victoria body would have lead the pack with the change to one piece apron, even though the early ones may have had the earlier style aprons. At the same time, I doubt that they ever had the earlier tank and instrument panel and speedo.
Y-Blockhead 09-23-2016 10:26 AM
Mike
Mine also.
