Bullets Do modern yellow female bullet connectors fit the Ford male bullets?
Re: Bullets Boy, I could say something about female connectors, but, I better not.
Re: Bullets Common Pat give me an answer. We'll talk about your problem later.
Re: Bullets 1 Attachment(s)
I have been using these (and the tool) that I got from Moss Motors. They work well with the original bullet connectors.
Re: Bullets Contact Tyree Harriss for original bullet wire harness connectors. 804-556-5200, Bumpass, VA. Great guy, easy to deal with.
Re: Bullets Think I answered my own question. Seems there are no yellow bullets made. Have to use the originals.
Re: Bullets I don't know what you mean by yellow bullets, but I have seen a couple different size bullets. The last ones I bought from Bratton's and Little Dearborn fit fine. I always solder them rather than crimp them.
Re: Bullets be careful when you solder the wires, some times it makes the copper stiff and brittle and it brakes easy at the solder joint
Re: Bullets I agree with Tom if you're looking for male bullets... definitely solder any terminals on auto wiring; crimp terms are just asking for trouble.
Re: Bullets Quote:
Re: Bullets I've tried doing a quick fix on the road with a modern red/blue/yellow bullet into a Ford style reproduction female connector. I believe the reproduction male bullets are a little smaller. I had to do some adjustments, but it can be made to work in a pinch. They don't look the same, that's for sure.
Re: Bullets Quote:
No, the proper tools are NECESSARY. The crimper from Joe's Hardware won't do, you need a professional one. Like the factory uses. If you don't have one then you better solder the connectors. Non-factory crimps loosen, corrode, make bad connections that heat up and burn out. Solder, solder, solder. |
Re: Bullets Quote:
Re: Bullets Quote:
Unlike my son who does automotive electronics for a living, I just have never mastered the fine art of soldering. I have definitely had more failures with my own personal piss-poor soldering than I can count. |
Re: Bullets Quote:
The secret is to have very clean metal, a good flux, and quality solder, plus the right temperature. |
