The Ford Barn
-   -   Another Trans Tower Question (https://www.fordbarn.com/forum/showthread.php?t=204432)
Dino's A 09-11-2016 07:59 PM
Long story short-Has anyone used tension pins instead of the rivets on the shifter forks? In rebuilding my tower, I had both. I know the rivets are the original way to do it, but I like tension pins. Any problems with using the tension pins?
tbirdtbird 09-11-2016 08:08 PM
Re: Another Trans Tower Question
if you mean roll pins, or split pins, then yes it is done all the time, and they are waaaay easier to install
Dino's A 09-11-2016 08:51 PM
Yes, I do mean roll pins. My bins at the hardware store say "tension Pins". I knew there was
a better name to describe this. Just to add to this, the rivets I bought seem kind of cheap.
I'm going with the roll pins. Thanks Guys!
Dino
Mike 09-12-2016 06:34 AM
What size roll pins do you use ?
Mitch//pa 09-12-2016 06:53 AM
Don't let the judges know... Some have X-ray vision:)
