Photo on back of recent Model A News... As you can see from the photo on the back of Model A News, the body is being lowered onto the chassis. So the question is this...was the distrubutor taken off the engine, screwed onto the ignition cable, thus reassembled onto the engine (this would have to be with the instrument panel already secure in the body); OR was the instrument panel NOT already assembled and secure within the body and the ignition cable was turned and screwed into the distrubutor, thus not removing the distrubutor from the engine.
Hmmmmmmm? Pluck |
Re: Photo on back of recent Model A News... Steve, Something is missing.? Maybe a picture
Re: Photo on back of recent Model A News... Pluck
I`m sure they removed the distributor. and same with the head nut. a long with that question how did they torque and re torque the head. |
Re: Photo on back of recent Model A News... Torque wrenches weren't used when the Model A was manufactured.
Re: Photo on back of recent Model A News... I know of MANY engines rebuilt and that served for many years by mechanics who I am sure did not have a torque wrench. I'm not saying that is a good thing, just a fact.
Re: Photo on back of recent Model A News... 1 Attachment(s)
Re: Photo on back of recent Model A News... Quote:
Re: Photo on back of recent Model A News... you developed a feel for how tight bolts were.
Yes as we used to say a Calibrated elbow. Of course some used say tighten them down till they smoked , then back them off half a turn. |
Re: Photo on back of recent Model A News... Which way is the line moving? the car behind the vicki is an open car (side note : light color wheels) already has the body on. the next one is a closed car already attached. yet there is a closed car body further back ready to drop.
Re: Photo on back of recent Model A News... I don't know the answers, I WASN'T around then & just when I figger out the answers, they CHANGE the questions????
Bill Confused |
Bill W. |
Pluck |
Re: Photo on back of recent Model A News... I would agree they removed the distributor to screw in the pop out cable and the head nut was loose to attach the clamp. The speedometer cable is through the firewall and hung over the coil.
What is that mushroom shaped thing on the front left bumper of the Vicky and not on the Roadster or sedan? Could it be the tow to move the chassis from the front of the picture to the rear? Also, how did they attach the open car bodies for the drop onto the chassis? Dave |
Re: Photo on back of recent Model A News... The bodies on the assembly line had the following attached:
Generator loom fastened to the terminal box and held upwards by a hook Popout switch cable protrudes from terminal box and hangs loose distribute Speedometer cable protrudes from firewall and hangs loose Info from photo page 54 of book "The Ford Factory" |
Re: Photo on back of recent Model A News... Before Torque wrenches the bolt where tightened by degrees. Tighten the bolt and then add 20 degs. to a 1/4 bolt and you'll find it's torqued preclose to spec. (20Lbs.)
I learn't this from a german guy I worked with. He torqued all the hardware this way. He'd tell me to put a torque wrench on it and he'd be within 1 lb. of the spec. It's all what you learn. John Poole |
Re: Photo on back of recent Model A News... It's a speed wrench hanging on the bumper..
Re: Photo on back of recent Model A News... I know they did not have torque wrenches back then, so I guess I need to rephrase the question, how did the factory get the head to seal. now days we will tighten (torque) them three or four times and hope they they don`t leak. I`m with Jim on the speed wrench.
Re: Photo on back of recent Model A News... I think I've read that the dealer did some retorque within 50 miles.?
They threw a plug / head nut wrench in the tool kit and the dealer /owner checked. the owner would also scrape the carbon every spring and lap he valves every other. |
