The Ford Barn
-   -   ID of water outlets on pre-49 heads (https://www.fordbarn.com/forum/showthread.php?t=203061)
tubman 08-22-2016 07:00 AM
Like the title says, I would like to get some input as to the inside diameter of the water outlets on pre 1949 Ford V8 heads. I would like the measurements for as many varieties of heads as possible; stock, aftermarket, cast iron and aluminum.
I need the information for a project I am contemplating. So if you have a head handy, could you throw a tape or caliper on it and let me know what it measures? Thanks.
V12Bill 08-22-2016 09:54 AM
Re: ID of water outlets on pre-49 heads
Hose I.D. is 1 3/4".
tubman 08-22-2016 10:03 AM
To make things clear, I need the ID of the outlet on the head, not the hose.
keith oh 08-23-2016 03:00 PM
1935 head ID opening is 1 7/8, pump is 1 1/2. On both head and pumps I find a variation of about 1/32 in.
tubman 08-26-2016 03:08 AM
Surely someone out there has a 59A, 81A, Edelbrock, or Offenhauser out there they can throw a tape on.
scooder 08-26-2016 07:34 AM
I'll have a measure up this weekend mate, got 81A aluminium and iron, 59A iron, offy 59A, 37 Ford iron, 8BA iron. I'll post the dims.
Martin.
JSeery 08-26-2016 08:06 AM
Modern Edelbrock 1.45 - 1.48
Gary in La. 08-26-2016 09:31 AM
Pair of 81A (A) heads measure 1 9/16"
38bill 08-26-2016 10:24 AM
59AB = 1.9 OD and 1.565 ID. The dimensions vary a bit due to the roughness of the casting.
tubman 08-26-2016 10:37 AM
Thanks, guys, that's enough to get me started. Any others will be appreciated.
russcc 08-26-2016 03:58 PM
Navarro, new in 2006, bought them from Barney before he left us. ID 1.385". Have an old set of Navarro's, but can't get at them to measure yet. May have some stock ones, will check and report back.
