The Ford Barn
-   -   42 Ford overheated (https://www.fordbarn.com/forum/showthread.php?t=202732)
edhd58 08-16-2016 11:19 PM
42 Ford overheated
Will using a modern thermostat in the 226 flat 6 cause it to overheat?
Long story short, the generator either moved or the belts stretched and the fan wasn't spinning to pull air through the radiator. It blew anti-freeze out of the radiator and did percolate a little bit.
I fixed all that and I am thinking it may be be running a little hot at 60 mph. 185 to 190 with a modern style 180 thermostat.
The engine was rebuilt, but the machine shop did not acid soak it, they baked it. They've been doing engines for a long time (40+ years) and say they've always done this.
It has the 0 pressure cap, but I think I may want to use a 4lb cap. It has a NOS radiator and modern style NORS water pump (curved fins vs straight fins).
Ken/Alabama 08-16-2016 11:56 PM
Re: 42 Ford overheated
Use a pressure cap.
JSeery 08-17-2016 06:57 AM
185 to 190 is not bad as long as it stays there!
Snouts out 08-17-2016 09:13 PM
Did you ever have the radiator rodded out? I'm sure there are shops in Louisville!
edhd58 08-18-2016 10:50 PM
Snouts, its a brand new radiator
Snouts out 08-19-2016 04:41 AM
Tighten the belt up ,and you ought to be good to go!
scooder 08-19-2016 07:20 AM
4lb cap and tighten the belt. More betterer.
Martin.
