The Ford Barn
-   -   edelbrock heads (https://www.fordbarn.com/forum/showthread.php?t=200175)
flintstone 07-10-2016 09:42 AM
edelbrock heads
Have a pair of old Edelbrock heads and trying to identify the year or anything about them the only markings I can find are F8m85 on the head
Thanks
JSeery 07-10-2016 10:41 AM
Re: edelbrock heads
Photos would help. Type of lettering, etc.
38 coupe 07-10-2016 10:49 AM
Re: edelbrock heads
Can you post pictures of the heads? Makes identification much easier. Top and combustion chamber side both if possible.
Ol' Ron 07-10-2016 01:13 PM
Re: edelbrock heads
The 8/85 is the Cr for 239/255 when new. No telling what they are now. Just CC then, the skin cut then to make sure they are flat. Nice find.
tubman 07-10-2016 03:39 PM
Re: edelbrock heads
Also, make sure you run the proper plugs. The stock heads usually use a Champion H-10 or equivalent, which is a 7/16" reach plug. These will be shrouded in these heads and leave sharp threads exposed that can lead to pre-ignition. Whatever you do, don't chamfer the plug holes from the inside; it will reduce the holding power of the threads in the aluminum. Most older aftermarket aluminum heads I've seen take a Champion "L" series plug, which are 1/2" reach. I have seen a few older heads that used 3/4 reach plugs, but I believe they are pretty rare.
Before you install the heads, get a few different plugs and screw them in and look at the from the inside. If you compare what you see to the stock configuration, it'll be pretty obvious what you'll need.
flintstone 07-11-2016 10:09 AM
Re: edelbrock heads
5 Attachment(s)
Attached some photos of the edelbrock head trying to identify.
Thanks
4t8v8 07-11-2016 10:45 AM
Re: edelbrock heads
Can't help you on the year but I have an identical set of them on my 8BA. Found them highly used on Hemming's in 1985. The guy I bought them from said they had run them on a drag car for years. Gotta be pretty old. The numbers on mine are F7.5 M8.
Ol' Ron 07-11-2016 11:38 AM
Re: edelbrock heads
These look pretty good to me. With just alittle work should preform well. Check piston to head clearance.
Ol' Ron 07-11-2016 11:41 AM
Re: edelbrock heads
FYI, they won't clear a hi lift cam. I clearace then at a 5 deg angle for the l-100 which doesn't remove much material.
flatjack9 07-11-2016 12:19 PM
Re: edelbrock heads
They look like they have been milled already.
4t8v8 07-11-2016 09:20 PM
Re: edelbrock heads
I had mine milled to insure flatness and am running a Max 1 cam with no clearance problems.
