The Ford Barn
-   -   30 Zenith Carb (https://www.fordbarn.com/forum/showthread.php?t=198039)
William Kelchner 06-08-2016 05:35 PM
30 Zenith Carb
My 30 appears to have a carb problem. Idles great but put it under load and it starts coughing back through the carb. Forum member and I think it is acting like a float problem. Has good fuel flow. No starting probs, no overheating issues. Tried numerous GAV settings all to no avail. I have read that a sticky/hung float can exhibit symptoms like this. Now to the point I could not make it 1/8th of a mile back to the driveway this morning . Thanks
700rpm 06-08-2016 05:59 PM
Re: 30 Zenith Carb
If this just started, I would suspect it's not the carb. My first thought is condenser.
Mitch//pa 06-08-2016 06:01 PM
Re: 30 Zenith Carb
Are the points gapped ok
kenparker 06-08-2016 08:28 PM
Re: 30 Zenith Carb
In the model A world 85% of the carburetor problems are electrically generated.
William Kelchner 06-09-2016 11:46 AM
Re: 30 Zenith Carb
:confused::confused: Yep it is a constant problem and prevents me from even attempting to venture out with the car. Love the quote. One thing that stumps me is the car will idle great, rev the he$$ out of it and it is flawless, but don't try to drive it. Oh well - thanks for the responses. Have a good weekend.
txkhog 06-09-2016 12:57 PM
Re: 30 Zenith Carb
also check your coils, plugs inside cap. when there is a load on the engine it takes more spark energy to fire the plug and the spark may be finding an easier path to ground than across the plug gap.
mrraford 06-09-2016 01:04 PM
Re: 30 Zenith Carb
Couple of thoughts here:
you may want to check to make sure the jets are not clogged in the carb.
condenser could be the answer.
is it timed correctly? Is the timing advance working properly?
make sure your distributor and coil are working properly. ie point gap, timing setting, good coil, good condenser.
We would like to hear the ultimate answer here. Please report back.
30ccpickup 06-09-2016 01:20 PM
Re: 30 Zenith Carb
Backfiring Under Load (throttle wide open at relatively low rpm’s) often indicates a problem in electrical/ignition/timing.
Culprits include:
Insufficient point gap (should be set at .018 to .020)
Timing
Bad condenser
Bad distributor body
Frayed wire between upper plate and lower plate on the distributor
Intermittent connection of the ignition switch
As Mitch said I, would start with point gap.
William Kelchner 06-09-2016 02:11 PM
Re: 30 Zenith Carb
Ok you guys thanks. I shall go through everything over the weekend, saving the carb for last, hopefully the culprit will be identified. I replaced the dist with an original type from Bratton's, the Zenith was also purchased from them, all this about 2 years ago. I also replaced the timing gear around that time.
I shall report back. Thanks again.
diomed 06-09-2016 06:30 PM
Re: 30 Zenith Carb
I've heard of this happening with bad muffler. A baffle collapses inside and restricts the exhaust flow. It'll start and rev in neutral just fine. Once you put it under a load it has no power. It's very rare but sometimes it happens.
Originally Posted by William Kelchner (Post 1306457)
...One thing that stumps me is the car will idle great, rev the he$$ out of it and it is flawless, but don't try to drive it. Oh well - thanks for the responses. Have a good weekend.
Quigley1930 06-09-2016 09:37 PM
Re: 30 Zenith Carb
Bill, I'll meet you in Marshall at the Ford dealer and we will get 'er done:D
Sewall
William Kelchner 06-10-2016 08:59 AM
Re: 30 Zenith Carb
Thanks Quigly, I can always count on you :D:D:D
William Kelchner 06-11-2016 03:51 PM
Re: 30 Zenith Carb
Well installed new points (orig style), the others did not look well and seen better days. Re-timed, checked spark (Tesla would be proud) :) Tried to make it around the block, almost made it but coughed several times. Carb tomorrow, another trip around the block. If no better there will be a lot more room in the garage. Have a good weekend.....
Bill K
Tom Wesenberg 06-11-2016 07:19 PM
Re: 30 Zenith Carb
Never give up..................it's such a good feeling when you find the problem.:)
700rpm 06-11-2016 08:01 PM
Re: 30 Zenith Carb
Condenser.
William Kelchner 06-12-2016 08:10 AM
Re: 30 Zenith Carb
Originally Posted by 700rpm (Post 1307663)
Condenser.
I have a "burn-out Proof" condenser, so the catalogue said. :rolleyes: I replaced my dist several years ago with a rebuilt one from Brattons, it had the cap installed. Tnx
Art Newland 06-12-2016 09:47 AM
Re: 30 Zenith Carb
Are you sure the fuel flow is OK? Too lean a fuel mixture for what ever reason can cause low power/backfiring. I took a very short video of my fuel flow after flushing my fuel tank and adding a new filter screen above the shut-off valve. I thought it was OK too, at first. Once I started getting it running better and producing more power it wasn't getting enough fuel.
https://www.youtube.com/watch?v=FAUI8MWo_Io
William Kelchner 06-12-2016 03:43 PM
Re: 30 Zenith Carb
Thanks Art. Yep my fuel flow is robust, disassembled the Zenith today, clean as a whistle, blew everything anyway. Did not go for a ride as it is in the high 90's. I plan a compression test tomorrow and that will do it, told the wife to cancel her Father's Day gift order (car cover for the A).....:confused: Cheers and thanks for all the suggestions.
30ccpickup 06-12-2016 04:30 PM
Re: 30 Zenith Carb
Devorce is to easy, she is testing you. There is nothing in the relationship that cannot be overcome, it just takes work and understanding. I love my mother's favorite quote, "it is easy once known". You have a simple problem that can be overcome, it will only happen once because next time you will know the answer. Be patient work it through, except the challenge.
Mitch//pa 06-12-2016 04:34 PM
Re: 30 Zenith Carb
What happened to Quigley's offer of help?
