ford generator Can you tell what wires and where to I attach them to make my 6v pos grnd generator motor so as to check it.1928 ford no regulator. Thanks::
Re: ford generator Connect 6 volts + to the body and connect 6 volts - to the output stud. It should spin slowly in the same direction it normally runs. Use a battery or charger of at least 10 amps.
Re: ford generator Quote:
Re: ford generator some 1932-33 generators had one or two wires exiting the generator case. These generators are occasionally found on Model A's.
Re: ford generator Your 1928 should have a powerhouse generator, and most likely it left the factory with a 5 brush powerhouse.
Since you are from Canada, here is how a Canadian powerhouse looks. See the picture I posted in reply #3. https://www.fordbarn.com/forum/showth...ian+powerhouse |
