The Ford Barn
-   -   Draining water from 1928 Model A (https://www.fordbarn.com/forum/showthread.php?t=196555)
jwschweitzer 05-17-2016 11:34 AM
Hi folks! Posting here for a friend. He's putzing with a 1928 Model A. His question is: "Does any water still remain in the engine when you open the drain petcock? Does it fully drain?"
I believe he's contemplating winterizing procedures. We read some various opinions about fully draining the engine vs using antifreeze.
Thanks for your help!
Roadster Rich 05-17-2016 12:05 PM
Re: Draining water from 1928 Model A
I can't tell you that not a drop of water remains, but I can tell you I have done this in Vermont for close to 25 winters and never had an issue. Antifreeze might keep you from some flash rust, but not necessary to protect from freezing.
Brentwood Bob 05-17-2016 12:42 PM
When you open the petcock on a motor of unknown duration in storage and nothing comes out stick a wire up to open any bridging from rust.
The voice of experience has spoken.
Bob
Fullraceflathead 05-17-2016 01:04 PM
If it's full before draining you should see 3 gallons of water drain out. I would pay attention to the possibility of the drain plugging up from rust and not draining completely.
Utopia Texas 05-17-2016 01:07 PM
I would use a antifreeze solution no matter what the weather. Engines this old
Need all the rust protection they can get. I've cleaned out 8 Model A blocks over the years and two were so thin due to rust that a pressure washer blew holes through the metal and made them useless.
C26Pinelake 05-17-2016 02:06 PM
I watched a person repairing a cracked block a month ago who also advocated that antifreeze was not necessary. You save a little if you are right but you spend a lot if you are wrong. Spend the few bucks. Wayne
Glenn C. 05-17-2016 10:05 PM
Don't forget the Model A engine tilts backwards from horizontal. Therefore not all water will drain out. Each time you drain straight water that you have been using as a coolant, you are encouraging another layer of rust, impeding cooling for the next season. 50/50 mix is the best.
700rpm 05-17-2016 10:11 PM
I use two Tbs of soluble oil with 3 gallons regular water for summers and change out one gallon of denatured alcohol for winter driving, which keeps my system unrusted and safe in Oregon winters. If I'm feeling nervous or a car is sitting for a while (month or more) I also add a pint of rust preventative.
