The Ford Barn
-   -   inside of pickup cab (https://www.fordbarn.com/forum/showthread.php?t=196532)
stillwater 05-16-2016 11:11 PM
My '30 pickup currently has four carriage bolts across the back wall, and a wooden rail inside to which the bolts attach. My understanding is that the cab was found down in a farmer's hollow at the back of the farm before restoration, and the back wall was caved in. When it was restored, the carriage bolts were attached to the wooden rail on the back wall inside the cab, above the seat.
I think maybe I've seen that wooden rail used in A pickups before, but not totally sure. Did Ford use these in their pickups? Or could this just be for support of the cab wall, that was put in by the previous owner?
waxhead 05-17-2016 06:17 AM
Re: inside of pickup cab
1 Attachment(s)
Here is a photo of my 31 pickup (prior to restoration) showing the wood across the back of the cab. I am guessing that this is what you are talking about. It is standard from the Ford factory. Hope this helps.
George Miller 05-17-2016 06:28 AM
Yes they used a wood rail and it had wood strips that went done to the seat frame , to suport the seat back.
waxhead 05-17-2016 06:40 AM
1 Attachment(s)
And how it looks now. Wood in black above the seat.
George Miller 05-17-2016 10:55 AM
1 Attachment(s)
Here is a picture of mine
Ed Saniewski 05-18-2016 05:40 AM
George, dose the 30-31 have 2 small clips on the wood to hold the seat back springs?
waxhead 05-18-2016 06:10 AM
The clips to hold the seat spring are welded to the back of my cab just below the horizontal piece of wood
George Miller 05-18-2016 06:14 AM
Not sure they were all the same. Mine has them on the bottom of the up rights. You can see them in the picture. They are real clear if you enlarge the picture.
Bob C 05-18-2016 10:31 AM
1 Attachment(s)
Here is a picture Neil Wilson posted on the AA site.
Bob
Ed Saniewski 05-19-2016 05:09 AM
Thanks Bob.
stillwater 05-22-2016 08:11 AM
Thanks for the pics and help.
