The Ford Barn
-   -   #51 6 bulb source? UPDATE (https://www.fordbarn.com/forum/showthread.php?t=195470)
Pilotdave 05-01-2016 05:39 PM
I need a 6 volt miniature bayonet #51 bulb for my Signal Stat 900 directional light system. Does anyone know a bricks and mortar store that sells these bulbs?
Thanks!
Dave
See #13 for update.
1931 flamingo 05-01-2016 06:07 PM
Re: #51 6 bulb source?
I think maybe Snyder's??
Paul
SeaSlugs 05-01-2016 06:13 PM
try napa? they have alot of oddball parts, maybe an electrical supply store? a real one not menards or lamp depo or something i mean an industrial place like fastenal, or grainger.
sometimes old old hardware stores still have a variety of bulbs around.
i know you said physical store but amazon has a 10 pack for $8...
http://www.amazon.com/10-PACK-Eiko-M.../dp/B003JW0F2E
macs for buck a piece
http://www.macsautoparts.com/ford_tr...t-bulb-51.html
Mitch//pa 05-01-2016 06:18 PM
Do a google search lots show up "#51 bulb 6volt"
http://www.cmwauto.com/MainMenu/Lamp...lamp_bulbs.htm
JOHN CT 05-01-2016 06:23 PM
Around my area we have a store called Battery Plus. They're a chain store. They carry a larg assortment of light bulbs. Check to see if you have one in your area. And give them a try.
jrelliott 05-01-2016 06:27 PM
You should be able to find one in your area also called BA9S. Since Radio Shack no longer supplies parts. I did a search on the internet for #51 bulb and there are a lot of LED bulbs that will replace that bulb and should last you a lifetime. Bulb Town has the for less that $.75.
Bob C 05-01-2016 07:32 PM
The NAPA part number is LMP51
Pilotdave 05-01-2016 07:37 PM
Thanks for all the replies! I'll start with NAPA in the morning.
The back story: after trying a variety of things to get the indicator lights in the Signal Stat to light up, I finally took it apart and found........no bulb!
Dave
Tom Wesenberg 05-01-2016 07:48 PM
The trouble is all the LED bulbs I've seen are only for negative ground systems, even if they claim they work on my positive ground car. I had to leave the business a negative on ebay because he lied about the application and wouldn't refund my money.
Bruce Adams 05-01-2016 08:03 PM
Hi Tom,
How/why does a bulb know which side is ground?
I have never tried to put hot to ground and vice versa but I would THINK a simple bulb should work.
No?
Tom Wesenberg 05-01-2016 08:09 PM
Regular bulbs don't care about polarity, but LED needs the current to flow the correct direction.
Bruce Adams 05-01-2016 08:10 PM
Thanks. I was trying to delete it after seeing LED Best-Bruce
Pilotdave 05-03-2016 04:10 PM
Re: #51 6 bulb source? UPDATE
Order the bulb through my local NAPA shop. Installed and working! Thanks for the assist.
Dave
SeaSlugs 05-03-2016 04:57 PM
what did they take outa your pocketbook for the bulb? curious...
Pilotdave 05-03-2016 09:44 PM
I had to buy a box of ten...about $8.50 for the box, so $0.85 for one bulb.
C26Pinelake 05-03-2016 09:56 PM
It could have been worse! Wayne
Bruce of MN 05-04-2016 08:54 AM
In the UK, try http://www.norbsa02.freeuk.com/goffystandardbulbs.htm
