The Ford Barn
-   -   28 roadster tail light placement (https://www.fordbarn.com/forum/showthread.php?t=195127)
32forddump 04-27-2016 06:04 AM
3 Attachment(s)
I am trying to mount the tail light on a 28 roadster. Does any one have a picture of where it attaches ?
Tom Wesenberg 04-27-2016 07:36 AM
Re: 28 roadster tail light placement
The lower left of the rear of your body should have 3 holes for the drum taillight bracket. I don't have a picture though.
jthomas6 04-27-2016 08:27 AM
2 Attachment(s)
Here's mine - hope it helps:
ian Simpson 04-27-2016 10:41 PM
I am contemplating fitting a right hand drum taillight, any assistance in the process would be appreciated.
32forddump 05-03-2016 07:27 AM
I do not have any holes on the left side. I do have 2 big holes near the center. Do you know what they are for?
jthomas6 05-03-2016 08:17 AM
I could be wrong, but I believe those to be for mounting a spare tire bracket.
BILL WILLIAMSON 05-03-2016 02:52 PM
Vermin has the 3 unused holes, on the L/H side. For LAFFS, I "thought" about mounting a TOW HOOK there--LOL
Bill W.
SteveB31 05-03-2016 10:15 PM
That is a 1929 body, not a 1928. The 1928 bodies had three threaded holes for the left tail light as pictured in the post above. the two holes you referred to in the middle are for the spare tire bracket
32forddump 05-04-2016 07:24 AM
So what would be the correct tail light for the 29 body?
jthomas6 05-04-2016 07:44 AM
The bracket and light would mount on the fender.
SeaSlugs 05-04-2016 07:51 AM
Thats also when they switched to the teacup style housing correct?
DougT 05-04-2016 09:24 AM
Correct.
32forddump 05-05-2016 02:23 PM
Thanks for the information. I guess I will have to get creative since I'm not running fenders.
CarlG 05-05-2016 04:36 PM
Try using one of these brackets that mount to the frame rather than the fender:
http://www.snydersantiqueauto.com/co...-light-bracket
Dick Carne 05-05-2016 04:43 PM
Ian Simpson
_______________________
Ian -
If your inquiry is with respect to the installation of a right-hand tail light on a sedan, then there should be no problem (I have added a right-hand taillight bracket to our early '29 phaeton). However, if your inquiry is directed at either a '28 coupe or roadster with a rumble seat, then a matching right-hand forged tail light bracket will not work if you also have the rear step plate with the original '28 forged step plate bracket; the plate will prevent you from properly placing the right tail light bracket in a corresponding symmetrical position to the left one. Good luck with your project.
Dick
