32 Inside window frame screws I have a 32 Tudor sedan.
On the inside window frames, there are some screws that attach to the door, then at the top of the frame there are funny screws that are almost like a tube with a screw that holds the frame to the door. Hope that makes sense? Does anyone know what these are called and where I might find some? I have four and a total of eight are needed. Thanks a bunch Jim |
Re: 32 Inside window frame screws Jim, Those are called tube nuts. The vendors used to carry kits. Roy Natrowitz?? for sure has them. MacMaster Carr?
Re: 32 Inside window frame screws If not Roy (Nacewicz), LeBaron Bonney carries them.
Re: 32 Inside window frame screws I'd call Roy first. If he as them, you'll know they will be correct and work as intended.
Re: 32 Inside window frame screws roy is at fordbolts.com
Re: 32 Inside window frame screws Thank you all so much
I don't think I ever saw one of those before. Glad I'll be able to get them Thanks again Jim |
Re: 32 Inside window frame screws I got some from C&G last year. Part #1102, kit included 10 tube nuts and screws for $5.
Re: 32 Inside window frame screws Thankyou Neal
