ubscrewed shift lever On the first nights stop on a recent weekend tour, I noticed that my repo gear shift lever was starting to unscrew. At first, I was concerned that something serious was happening in the transmission. I drove it up and down the road in front of our hotel, and although it was kind of difficult find the right gear, it still drove ok without any strange noises. We continued on the tour and finally made it home. Today I removed the trans top and unscrewed the lever. I cleaned the threads, put a bunch of red Lock tight on them, and screwed it back together.
Today, after it set for 24 hours, I put it back together and drove it about 15 miles. All is good so far. Hope it lasts. |
Re: ubscrewed shift lever [correct me if I am wrong but did you not post this two days ago? Wayne[/B]
Re: ubscrewed shift lever Who makes the repro lever that has a connector? What is the reason for the two parts? Is the bottom made of a hardened material so the sphere does not wear? If so, I would be interested in purchasing the bottom part and the connecting piece so when mine wears, I can have a repair on hand. Don/WI
Re: ubscrewed shift lever Quote:
Re: ubscrewed shift lever Another good reason to find an original part , restore and replate.
Re: ubscrewed shift lever I restored a few shift levers that I found at swap meets or removed from my spare transmissions. At least one had fairly deep pits, which I removed by spinning it as I held it against my belt sander. They turned out nice after I got them nickel plated.
You can't have TOO MANY spare parts, of course. Joe K |
Re: ubscrewed shift lever One reason I heated mine to bend it, was because of a pic that was posted awhile back, with the lower end of a shifter, "tweeked" above the ball!
Bill Straight |
Re: ubscrewed shift lever Thought it was the Shi Tango Wong Corp. Maybe I was mistaken. Rod
It's getting late... |
Re: ubscrewed shift lever Thanks for all the help guys!! Don/WI
Re: ubscrewed shift lever If Macs was the vendor all 3 of us are likely correct on who manufactured them. Rod
or if one could calculate the harness of the forks and match the ball to them it may be the best of both worlds - both would wear out at the same time but may last alot longer in the long run than the current setups (ford original and repo shafts) Just thinkin out loud again... |
