The Ford Barn
-   -   47 ford convertible (https://www.fordbarn.com/forum/showthread.php?t=194881)
47-57 04-24-2016 05:58 AM
47 ford convertible
does anyone know the location and the purpose of a sash spring all I know the spring goes somewere in the top well just purchased new top spring came with top cannot find any info. tony
flathead48 04-24-2016 06:04 AM
Re: 47 ford convertible
Tony, do you mean the assist springs? I have a 48 and have never seen any other spring. Is this a LB top? Thanks, Rick
47-57 04-24-2016 06:50 AM
no they are 2-small springs about 18" long the instructions show they mount in the well they came with mounting brackets and poor instructions I purchased top from lebarron bonney barron no one knows were to mount
flathead48 04-24-2016 08:46 AM
I am stumped, I just installed their top on my 48 which is the same as your 47 and no springs came with the top. I think someone put them in your package by mistake because no springs other then assist ones go to that top. They may be for 49 which I believe has cables along side instead of snaps.
paul2748 04-24-2016 08:04 PM
There are booster springs for a 48 (and I assume 46 & 47) converts. There is a picture in the 41 - 48 service bulletins, page 317. It does not show where the bottom is mounted. I installed then in my 48.
Since the picture showed what I thought to be be straight up and down with the top up, I assumed there was a bracket down below. Any bracket that should have been was missing, so I made one. I don't know if the stretch is right, but it's been working ok for the last 30 years.
jimTN 04-25-2016 06:38 AM
I know one 46 conv. restorer that leaves those springs out, says they are not needed.
