The Ford Barn
-   -   TH350 sounds like marbles .... (https://www.fordbarn.com/forum/showthread.php?t=192022)
ricklove 03-20-2016 10:32 AM
Also posted in the H.A.M.B.
Had a rebuilt TH350 installed last June (less than 5k miles ago). No problems until yesterday coming home from 200 mile trip. About 30 miles from home, started hearing what sounded like "marbles" as it shifted into 2nd gear. First few times, the sound was very short, but as I continued to drive, it got louder and longer when in 2nd. No symptoms of slippage, and noise is only in 2nd gear. Checked fluid when I got home; a tad low, so I added fluid and drove around the block. Still sounds as bad as previously. Coincidently, my brake master shows slight sign of leakage, and pedal does not always return to full up position by itself. Any ideas?? Many thanks!!
Kahuna 03-20-2016 10:40 AM
Re: TH350 sounds like marbles ....
What?
Dec211975 03-20-2016 11:27 AM
It could be a number of things but from my past experience as a transmission repair shop owner I would suspect the following in order of probability, all would require transmission removal.
(1) rear planetary gear set failure.
(2) low roller clutch failure (locked in first freewheels in second)
(3) roller clutch failure in torque converter ( this is probably the least viable the noise would be coming from the front of the transmission and you would either not be able to pull away from a dead stop because the stator would be free wheeling or locked and then you would not be able to get to cruising speed " always multiplying torque")
In any case if you drop the pan you undoubtedly are going to see a lot of metal.
Best of luck,
Brian
donald1950 03-20-2016 12:31 PM
it was always interesting to see how much metal debris an auto trans could make and still operate..... `
BUBBAS IGNITION 03-20-2016 02:18 PM
And thats hooked to a flathead ?????
ricklove 04-15-2016 09:36 AM
Fixed under warranty! Found broken sprag and bad pump. Trans was rebuilt last June and had a 12 mo/12k warranty.
V8COOPMAN 04-15-2016 10:36 AM
Not quite! Ricklove describes his STREET-RODDED '48 in another thread (BELOW). DD
"Fairly new owner of what appears to be a very well built 1948 Ford 2 dr sedan street rod and I have VERY little documentation history or information about it. Based on interior, air cleaner, and radiator; I believe it's about a 20 year old build. It shows a little over 16k miles on the VDO gauges (all work accurately) and it has a Mustang II rack & pinion w/power steering, ZZ4 crate engine (new in 2007), TH350 trans, air & heat, etc, etc, etc."
51 MERC-CT 04-15-2016 10:43 AM
Must be one of those 'used to have a flat head cars':confused:
ricklove 04-17-2016 09:58 AM
My 1st car (Apr 1964) was a black '47 Ford tudor sedan (with a flat head). Two years ago, my wife "talked me into" buying a street rod. Within 2 weeks, I found a black '48 (year I was born) tudor sedan on eBay (Portland OR) built just the way I wanted. Bought it sight unseen; after LOTS of pics, phone calls to seller, and inspected by 3rd party garage. Have put almost 17k miles on it and enjoy EVERY mile driving it. I can attest that almost every hobby is expensive to acquire and maintain. I am a very fortunate and blessed man to have a great wife and a great life. My motto is: "So long as I wake up, the day has a good start!"
Pat/Ohio 04-17-2016 05:45 PM
Hi Rick....Are you planning on driving the '48 to Blanchester, OH this May? Hope so!
Pat
