Radiator upgrade. Thinking about putting a new Radiator in my f1 (v8). still have the original one in there right now, took the cap off and the top holes/slits are packed with gunk.
so... if i buy new what should I be looking for? or... should I get the original one cleaned out if cost effective? any thoughts? marko |
Re: Radiator upgrade. I bought one from Speedway for my panel, made a world of difference with a warm engine.
Re: Radiator upgrade. Quote:
Re: Radiator upgrade. If your tanks are good, I would get it re-cored with a high efficiency copper core
Re: Radiator upgrade. I bought an F-1 radiator from LMC truck and it did worlds of wonder for my truck. Price was 200 less than re-coring mine.
Re: Radiator upgrade. Just went through this recently. Weighed the options and decided to re- core the one in my truck. Had a four row, brass core put in with new petcocks and overflow tube. I knew mine would fit after the work was done. Should have done it sooner. Nice, steady temp readings now, even under a load. Find a quality radiator shop and see what they say. Good luck.
Re: Radiator upgrade. The one from LMC fit just fine. The quality radiator shop wanted 700 to do mine. The truck is now in Japan, has been for the last 8 years and no issues with the radiator. Just my personal experience.
Re: Radiator upgrade. Whatever .... don't waste your money on a new aluminum radiator. Recently read a lab test report in a PU resto mag that said there's barely any difference in heat dissipation between copper vs. aluminum radiators.
Re: Radiator upgrade. Had one re-cored for my '49 last summer. Brass with copper fins, sand blasted all the metal and tanks, resoldered the inlets and outlets and painted. $550.00 Looked like new!
Re: Radiator upgrade. 1 Attachment(s)
I just got an aluminum, polished one from Champion in Calif.. Love it. $185 with free shipping. Was here in four days (Arizona) Quality welds and workmanship, and the mounting holes lined up. My truck has the two top and two lower inlets/outlets. Dis a hundred mile cruise yesterday in 90 degree weather and ran at about 200 degrees. Did not use my a/c. http://www.championcooling.com/
Re: Radiator upgrade. I also got one for my F1 from LMC, it bolted in with no problems. the only thing I didn't like was the black paint job, top end was full of paint runs. other then that truck runs cool
Re: Radiator upgrade. anybody know who makes the LMC radiators?
Re: Radiator upgrade. Got mine from Superior Radiator from Mount Clements,Michigan.$310.00delievered to my door step.Had it on eBay.Fit perfect
Re: Radiator upgrade. do the stock fan shrouds fit on these aftermarkets? if so, which ones? thanks, jack
Re: Radiator upgrade. Can't tell you if it will fit the "Champion". I run an elec fan and there was pleanty of flange area for me to fasten both the fan and my a/c condenser. I would give them a call and ask. Sure is a sweet product, and priced right. (See my above post for web site)
Re: Radiator upgrade. I also used a champion, but I had a 302 and the stock shroud wouldn't work with the fan on the engine. I ran it like that for a while and later switched to electric.
Pretty happy with quality, fit, and finish of the aluminum radiator...very inexpensive and likely cheaper than a re-core. |
