What is a good head stud for Offy heads I am using offenhauser heads on my 8BA mild street build. The problem I am having is there seems to be no middle ground on price. ARP studs are nearly $500 :eek::eek: and the cheap versions ($99 Speedway) have such awful reviews for fit and proper length, I am scared to order them. Does anyone know of a stud that is some what reasonable in price yet of quality enough to do the job.
Re: What is a good head stud for Offy heads Best studs are from Roy Naciwiecz, but I would use bolts.
Re: What is a good head stud for Offy heads whatever you use, also use flat washers so you dont dig into the heads with the nut or bolt head.
Re: What is a good head stud for Offy heads I used studs from Mac's. No complaints here...
Re: What is a good head stud for Offy heads I have used the studs from Mac Van Pelt on the last motors and been happy.
I must confess 60 or so years ago when we bought our oil in bottles at Western Auto we never hesitated mixing studs and bolts to attach a head and if we were short a bolt or two we'd run down to Arthurs Hardware (they had 7/16-14 no grade hex head fasteners). $500, really ? Charlie ny |
Re: What is a good head stud for Offy heads 2 Attachment(s)
The bolts aren't a bad idea but it's easier to "seal-up" the studs in my opinion? One thing I would add, you should know the exact lengths on all the bolts/studs you need, we find different vendors tend to mfr with different heights on the head holes. Thanks, Gary in N.Y. P.S. I also recommend using washers under the heads of the bolts if this is where you end up but different ones than are found in ARP's stud kits. See the photo below here. They are "special" for this particular platform. You almost cannot see them on the finished assembly. They are chamfered for the head bolts and run about $50.00/set. |
Re: What is a good head stud for Offy heads Quote:
http://www.speedwaymotors.com/ARP-15...ads,88074.html |
Re: What is a good head stud for Offy heads Gary ... "Very" nice pieces !!!!
Cheers Tony |
Re: What is a good head stud for Offy heads I have used the 99.00 head stud set from Speedway on several motors with no problems to date.
Re: What is a good head stud for Offy heads They are chamfered for the head bolts and run about $50.00/set.
I have the ARP setup. Does the chamfer on the washer go up or down? |
Have they been used on Alum heads like Offenhauser or Edelbrock, the problem with the cheap set seems to arise when used with those types of heads. I prefer a stud and I know about the washers. I also prefer a stainless steel acorn nut for the cap. Most of the reviews on the lower priced studs complain about loose fitting and the length not being correct. I am only asking if anyone knows of a better deal and if so point me to it. I am not here to discuss the merits of bolts over studs. |
Re: What is a good head stud for Offy heads Bolts with harden washers and 7 thread engagement. Grad e #5 will be OK, but you'll feel better with grade#8 torque to 45 ft/lbs for 3 heat cycles.
Re: What is a good head stud for Offy heads 1 Attachment(s)
The stud bottoms work best when they are about .750"/.800" long to go into the deck surface. Care needs to be taken with the few above the heat-crossover. The ARP studs are available in either the short bottoms (.750") or the long bottoms (1.000") see the photo below, depends on how they are ordered. You can use the longer ones but a few will need to be shortened. Thanks, Gary in N.Y. P.S.Building these for a living over here I would NOT use any other studs than the ARP line, it's the way it is here. I need to know I have the best fasteners available to stand behind any build! |
The Flatheads now all have them! (See the photo below) I never cared for them, after the studs are in service for some years trying to remove them with an Allen key is all but useless. They "round-out" or break the wrenches? If you look at the photo (stud/poly-lock) the best method to take them out is simply use a 7/16-20 poly-lock, much easier, they can also be installed with them? Thanks, Gary in N.Y. P.S. To be fair with respect to Speedway's pricing, we do not include the "acorn" nuts in our kits, not sure where they would be costwise?? |
Re: What is a good head stud for Offy heads Use speedway also
Re: What is a good head stud for Offy heads And people wonder why it's so expensive to build a flathead??
