'47 Super Deluxe V8 Distributor There is a screw sitting on top of my distributor that appears to be some kind of an adjustment screw. I noticed it when I was installing the fan and did not want to use it to pry the fan up to get tension on the belt. Anyway, can someone tell me what that screw is for? Thought maybe it might be for timing or something like that.
Re: '47 Super Deluxe V8 Distributor dw,
It is an adjuster for the vacuum operated 'brake' of your distributor, you were right in not using it to pry against. Charlie ny |
Re: '47 Super Deluxe V8 Distributor Here are the instructions for adjusting the vacuum brake:
http://i1059.photobucket.com/albums/...orServicea.jpg |
Re: '47 Super Deluxe V8 Distributor Many thanks to the both of you. Much appreciated.
Danny |
