34 sun visors I have the 34 sun visor bracket and wonder if I can use a later (35,6,7...) visor by modifying the pivot attachment end and mount it in the 34 brackets? Has someone done this? Will the pivot end still be long enough when removed from the later bracket?
Re: 34 sun visors Terry, The 34 deluxe only visor mounting pivot bracket has tapered holes which the tapered visor frame rod fits into under spring tension to give the visor some friction. Im not sure that the 35-36 visor frame rod has that same tapered end as the mounting bracket is totally different. Regards, Kevin.
