piston screw up I ordered a set of piston for my flat head not paying much to it I did not look to make I had the right stroke to day I was going over every thing and I ordered 4.125 instead of 4.250 hoping the guy will take them back
does anybody has a part number for ross piston with a 4.250 stroke and a bore 3.125 or 3.375 |
Re: piston screw up Quote:
If it is NOT a listed "stocking" number then it would be 100% special-order deal? In other words a "custom" piston. They have the 3.375" bore for the 3.750", 4.000" and 4.125" strokes. There is a stocking part number (80576) for the 3.312" bore x 4.250" stroke. These are the ones we supply with our own kits. I'm assuming this is the size meant above (3.125") in your post? (Add) Got your P.M. also! Thanks, Gary in N.Y. P.S. Good luck exchanging them (for the 3.375"), not sure how that would work with the vendor that made the sale?? |
Re: piston screw up ok thanks
Re: piston screw up I might have to get hold of you I might be stuck with these pistons who knows
Re: piston screw up Do you already have the crankshaft? If not, just go with a 4 1/8 stroker . . . you'll still have plenty of fun! :)
Also, I'd much rather use a 3 5/16 bore piston anyway - don't go all the way to 3 3/8, just no need for it. If you order custom pistons from Ross, they'll be quite a bit more money than the stocking ones. Hopefully they have a piston that will work for you - also, if they have the 1.5, 1.5, 3.0 metric rings as an option, definitely go that route. |
Re: piston screw up I have my crank and rods just didn't pay att when I ordered my piston hope he will take them back and trade me for 4 5/16 bore one hope I will find out to marrow
side not the block I had was cracked in 2 spots on the same side head bolt to the water passage I got a 59 block from a guy clean it up with a wire brush it looks good going to take it in on Monday to get clean and tested |
Re: piston screw up 31, try and make sure you are quoting the numbers right, you seem to be getting your 3s and 4s mixed up when talking about bores and strokes.
Cracks between a head bolt hole and the water passages are very common. They are not normally a job stopper and most engines running today have cracks there. Don't disregard a block if that is all that is wrong. Mart |
Re: piston screw up no it has a crack in a lifter guide all the way down
Re: piston screw up got hold of the guy that I'm getting piston from he said he would get me the right ones
Re: piston screw up got lucky they were gust about to get shipped them out he was able to stop them and get me the wright ones
thanks Gary for your help |
Re: piston screw up well I thought I got straight out no the guy will not give me a tracking number I ask every day he said should be shipped out that day and should have a tracking number that night this is been since Monday
