flat head six 226 I bought the pertronix 1261 ignition. Wondering how to run the wires through the distributor housing. I see how to remove the points and condenser I also have the negative wire from the distributor is hooked to a resistor then to the coil. This has been changed to a 12 volt negative ground system. Any pics to where I can go on line to take a look? Thanks :D
