1931 Brake Rod Length Dimensions 1 Attachment(s)
The Model A Restorer's Guidelines and Judging Standards, Page 7-7, bottom of the page, Identifies dimensions of the brake rods, design from May 1928 to November 1929.
Question, what are the dimensions of the brake rods for 1930 - 1931? Are they the same as the ones identified on this page? |
Re: 1931 Brake Rod Length Dimensions They are just giving the length of the non adjustable rods used for a short time
in 1928. Bob |
Re: 1931 Brake Rod Length Dimensions Should anyone wish to know, the brake rods should be adjusted to 51 7/16 - 51 1/2. This is taken from Model A Ford Mechanics Handbook Vol I, page 1-45, Step 1.
Re: 1931 Brake Rod Length Dimensions try this thread:http://fordbarn.com/forum/showthread...+length&page=2
if I got it right: svc brake 50 1/2 ", ebrake 40 7/8" bob |
Re: 1931 Brake Rod Length Dimensions Quote:
Re: 1931 Brake Rod Length Dimensions Is that end to end or hole center to hole center?
Re: 1931 Brake Rod Length Dimensions Thank you
Re: 1931 Brake Rod Length Dimensions |
