The Ford Barn
-   -   Information on Model B Head (https://www.fordbarn.com/forum/showthread.php?t=189735)
A Bone 02-21-2016 10:48 AM
3 Attachment(s)
I have a Model B head that I don't know much about; is this the head that has the high compression, if so what is the compression ratio? Thanks for any help
Bob C 02-21-2016 11:55 AM
Re: Information on Model B Head
That's a Model A police head 5.2 ratio, the Model B head had a large
letter C on it. See the link to Vince's site http://www.fordgarage.com/pages/head...ssionratio.htm
Bob
glenn in camino 02-21-2016 12:59 PM
Compression is 5.2. I'm running them on 2 of my cars. Love them both. Someone did a really god job grinding the B off one of them so it looks like a stock head and passes fine point judging.
Chuck Sea/Tac 02-21-2016 05:06 PM
I did not know that.
DougVieyra 02-21-2016 05:50 PM
Glen in Camino, post #3":
". . . Someone did a really god job grinding the B off one of them so it looks like a stock head and passes fine point judging."
____________________
That is exactly what I did to my 'B' Police Head back in 1975. At that time (long before there were engine shops specializing in making Model A 'Touring Engines') I also had the stock engine on my '28 Phaeton rebuilt with a 'C' crank (from a '34), 5 bearing cam, etc., etc.. following the recommendation as laid out in the 'Speed' book of the time, Fisher's FORD SPEED MANUAL*, a Floyd Clymer publication from 1952.
As I was restoring the car to meet Blue Ribbon judging standards, I carefully ground off any indications that the head was a 'B' Police Head.
_____________________
*A quick peek at Amazon.com just now, gave the following :
Ford Speed Manual: 1952 Edition May 1, 2007
by Bill Fisher
Paperback
$19.95 Prime
Only 1 left in stock - order soon.
DougVieyra 02-21-2016 06:02 PM
Just to clarify: The 'B' head (with the 'C' marking) for the '32 - '34 4 cylinder engines, had a 3 hole mounting for the Pump/goose-neck unit; quite different from the Model A head. And while the heads are inter-changeable to the engine block, the water-pumps are not inter-changeable on the heads. Difference in heads is easy to identify.
glenn in camino 02-21-2016 08:11 PM
Originally Posted by forever4 (Post 1245636)
The original issue of the "B" suffix head did not have the "B" on the head. It was added as an early change per the engineering record.
Maybe I have one of those. Thanks for that info.
