The Ford Barn
-   -   Cracked Piston (https://www.fordbarn.com/forum/showthread.php?t=189658)
Hank Z 02-20-2016 11:49 AM
Cracked Piston
I have cracked piston. I was cleaning the carbon off the top of them and noticed a small crack. The intake valve was not seating properly on that cylinder causing the backfiring. In general, what could be some of the causes for the piston to be cracked?
jrapose 02-20-2016 12:27 PM
Re: Cracked Piston
Using starting fluid can crack a piston or water will do it too.... what has happened is that at one time too much pressure was developed....in the ole days we used a fine spray of water to decarbon a chamber...but you had to be careful not to spray too much water or you would risk cracking a piston....water flashes into steam and removes carbon deposits.... at one time you might have had a leaking head gasket..that does it too.
Tom Wesenberg 02-20-2016 02:37 PM
Re: Cracked Piston
I've seen burned pistons, and one piston with a crack in the skirt, but don't ever recall seeing a crack in the top of a piston.
Hank Z 02-22-2016 04:42 PM
Re: Cracked Piston
thanks for your responses. I think I may look for another engine as i am seeing other issues as well.
Synchro909 02-22-2016 04:58 PM
Re: Cracked Piston
If there is a crack in the top of the piston, I suspect you got it just in time. It would have broken very soon and caused a whole lot more pain It doesn't surprise me that you are finding other issues. Sounds like another motor or a rebuild is in order.
tbirdtbird 02-22-2016 07:34 PM
Re: Cracked Piston
too much advance leading to detonation which is very destructive
