Welting What do you use to seal either wire-on or hidem welting and do you use it both underneath it before you tack it on and then also in between it to seal it closed?
Re: Welting Larry are you doing your pickup or coupe?There is a good article with photos on installing tops?? search on line?http://www.modelahouse.com/tech/puroof/puroof_files/v3_document.htm.
Re: Welting Quote:
Re: Welting Thanks Gary, I am doing a 29 std Sept coupe and do not have the skill or patience to use metal front and rear roof trim so I am using the wire on welting that folds over once it is tacked down. Just want to know what I should put under it before I tack it in place and what I should put in it before I fold it over. I just want a good water tight seal.
Re: Welting I have used the black pure 100% silicone. but you need to be very careful about keeping it off of things, messy ! but works.may be other caulks available.
Re: Welting What about using the Locktite roofing black polyurethane? It stays a little pliable. Anyone use that?
Re: Welting Quote:
