rebuilt engines-not mine CT Model A Rebuilt engines - $1275 (Burlington,Ct)
© craigslist - Map data © OpenStreetMap Covey rd. at Rt 4 (google map) condition: excellent make / manufacturer: Ford model name / number: "A" size / dimensions: Stock I have 2 rebuilt Model A engines, Running on test stands, come and hear them run, Take your choice, $1275 each, Thanks, Dennis |
Re: rebuilt engines-not mine CT sounds too good to believe
Re: rebuilt engines-not mine CT Rebuilt means different things to different people.
Some thinks its a set of rings, a valve job and a coat of green paint. I'd be real leery of this one. On the other hand, if it was in real good shape to begin with, maybe it would be OK.... Caveat Emptor, and Good Luck |
Re: rebuilt engines-not mine CT Overhauled
Rebuilt Restored Remanufactured NOS NORS All terms that are overused and really mean nothing without some sort of confidence in the person using the term. |
Re: rebuilt engines-not mine CT Rebuilt to me means run unless you want to fix it.
Re: rebuilt engines-not mine CT Quote:
or "run" away? |
Re: rebuilt engines-not mine CT Whom ever or who ever is interested in one of the "A" motors. Should ask around in the area to see if the guy has a reputation. Contact a local "A"
club or anybody else into old cars. And see what shakes out. You never know till ya' ask....:) Bob-A:D |
Re: rebuilt engines-not mine CT I myself would be apprehensive ! Wayne
My 2 cents. |
Re: rebuilt engines-not mine CT When I was a kid I got stung on a "rebuilt" model A engine. It was painted nice. I took it home and took off the pan, and with the front main bearing removed, I could lift the crankshaft a quarter inch. After that, no documentation, no sale.
Re: rebuilt engines-not mine CT It's no wonder that people are reluctant to post once in a while. You guys are ripping him a new one when you have absolutely no idea what this person has for documentation. If I lived in the area and was in the market for an engine I would at least have a look and see what he has for documentation. Geeeez. My two cents worth. Don/WI
Re: rebuilt engines-not mine CT I don't know about the re-builder, but I have known the contact for many years. He is honest and is a friend. I am talking to him about a trade for a Model T engine now.
Re: rebuilt engines-not mine CT My $5 engine runs nice after a valve job, balance and a B cam. Ran ok before the work. It was a 1956 Sears rebuild that was used on a home made garden tractor until the early 80's. Than sat inside a friends storage until 2011. When I pulled the pan and it had very little sludge in it. Sounds good on the stand. Should run good enough until I can afford to rebuild the original engine for the delivery the way I want it. Rod
Re: rebuilt engines-not mine CT If you can rebuild the A engine for $1275. you are better than I. Rebuild means bringing the engine back to like new. That means boring cylinders, babbitting the bearings, grinding the crank, replacing the camshaft, new valves, lifters, both cam gears, balancing. Plus what ever else is wrong. Like valve seats, crack in block or head, cleaning water jacket. Plus labor. Maybe it was refreshed, like new rings and adjust the bearings.
I'm not saying the engine is no good. I'm saying I do not think it is rebuilt. |
Re: rebuilt engines-not mine CT 1300.00 wouldn't even buy the parts we use!!!!!!!!!!!!!!
Herm. |
Re: rebuilt engines-not mine CT Is it just possible that the rebuilt engine were part of a deal where the seller bought a bunch of stuff?? Does the original ad state anywhere that the seller rebuilt them???
Re: rebuilt engines-not mine CT Hey guys, I have to tell you that I am with Don/WI here. While it is OK to be a little skeptical and a lot cautious, nobody has any idea of what the actual condition of these engines are. The seller says he has them on engine stands, and that they are running. Well, with a running engine, if you have any experience at all, you can tell one heck of a lot by listening to it, racing the idle for a bit, and watching the exhaust pipe...
Since there is no "legal" definition of what a rebuilt Model A engine actually is, it is quite possible that these engines have had a top job and a bearing clearance adjustment. That could be done for the price asked here. I am not familiar with the seller in this case, but he lives about 2 miles from me. If I were in the market, I would certainly venture up the hill to see what he has. Gad! And I thought I was a grumpy old man...! |
