does dipper tray need filled I forgot to fill dipper tray and distributor is installed and wired,do i need to remove distributor and fill tray
Re: does dipper tray need filled I would not take the chance not too!
Re: does dipper tray need filled X-2
Re: does dipper tray need filled I guess removing dist is only way to fill dipper tray
Re: does dipper tray need filled Why wont it fill if you pour oil in the oil filler tube??
Bob |
Re: does dipper tray need filled the dipper tray will fill through the oil fill tube----if you loosen up the oil return pipe ,remove the spark plugs and crank the engine till oil comes out the return you will know the oil pump works and the valve chamber is filled
Re: does dipper tray need filled the purpose of a QT down the dizzy hole is to oil up the valve chamber so that the mains can get oil
the tray gets it from the filler neck |
Re: does dipper tray need filled Presumably you used assembly lube on the bearings? If not, put a quart down the dist hole so the valve chamber fills and the oil tubes to the center and rear mains are oiled. This will not fill the front section which feeds the front main. Crank the engine as noted above to get oil flow to the front section.
Re: does dipper tray need filled You can pull the one nut holding the cable clamp, back off the screw holding the distributor and lift it up. As long as you don't mess to much with it you will not change the timing. If you have to take the distributor off for some reason later it's the same thing. Just remember to torque the nut back down.
Re: does dipper tray need filled Quote:
Re: does dipper tray need filled Remove the oil drain tube from the valve cover then squirt a quart of oil into the valve chamber. This is a way to get around from removing the dist if that's an issue for you. .. This will prime the main bearings and you won't have to crank it over dry,, assy lube or not waiting for the oil pump to supply the oil up... After starting leave the lower oil pipe bolt loose to prove out you have oil pressure by oil returning to the pan....
Re: does dipper tray need filled not a new motor but i pulled pan and cleaned,its all clean and dry,guess will just pull dist add the quart,do not have clamp under head bolt,might be enough slack to lift up(its on my doodlebug)
